I have a Philips SP 100 Home theatre ( 5.1). I am unable to set the FM. There are two accesories of antenna but I am not sure how to fix them.
  • en_rah19
    en_rah19 May 12, 2012
    if you want to sell this product you can contact m on this no:- 9990036288
  • 1779 Answers
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Posted on Apr 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: My new Philips Cineos home
Reset the unit by unplugging it from wall outlet and replugging it. Try searching for station again.
Posted on Jun 14, 2008
SOURCE: Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Posted on Jul 09, 2008
SOURCE: Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
Posted on Dec 08, 2008
remington870
  • 48 Answers
SOURCE: need an fm antenna
If it uses a simple terminal clip (similar to a speaker connection) then extra speaker wire or lamp cord thats laying around works beautifully. But you could always visit a Radio Shack to get the proper stuff.
Posted on Apr 04, 2009
Unable to get fm radio reception on lg home theatre
You may have weak FM signals in your area. Do make sure you have the FM antenna attached.
Dec 08, 2014 | LG Audio Players & Recorders
Unable to get fm reception
Make sure you have an FM antenna connected. If that doesn't resolve your issue, you may have a damaged component in the tuner circuit.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Dec 08, 2014 | LG Stylish DVD Home Theatre System HT306SU
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
I GOT YOUR HELP PREVIOUSLY. RECENTLY I AM HAVING FOLLOWING PROBLEMS WITH MY PHILLIPS HOME THEATRE MODEL-HTS-3265. **** I HAVE BOUGHT ONE VIDEO CD OF VIOLIN BROTHERS LIVE CONCERT FROM ASHA AUDIO BUT...
It's possible that this DVD is not from the same region as the DVD player.
For instance, a DVD from India (region 5) will not play in a DVD player from the US (region 1).
You may want to check into that and post a reply here.
Mar 01, 2011 | Philips HTS-3565 Theater System
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Jun 19, 2010 | LG Televison & Video
FM WON'T RECEIVE STATIONS IT USED TOO BUT I HAVEN'T USED FM IN A LONG TIME. NOW ALL I GET IS STATIC. THE ANTENNA IS CONNECTED
Make sure that the antenna is properly hoked up. In most cases it just come loose, happens on my Pioneer system all the time. And if you have pets or it gets nudged or bumped frequently this can happen. If that still doesnt solve the problem I would recommend buying a new antenna available at most electronics stores.
Nov 04, 2009 | Philips LX3900SA System
Need an fm antenna
Apr 04, 2009 | Philips MX6050D System
No tuner output
Some home theatre receivers will not output sound until you ( LOCK INTO ) a radio signal, be sure you have a antenna connected and are receiving a strong signal. Unlike the older model you would receive static sound until you found a station.
Feb 27, 2009 | Gateway Audio Players & Recorders
Phillips LX3600 Home Theatre
Power up the set and open tray in DVD mode.
Press <9999> follow by <X> buttons on the Remote control.
where x = numeric 1 to 6 denoting the regions below:
Then show your region on TV
1 = USA
2 = Europe
3 = Asia Pacific
4 = Australia, New Zealand, Latam
5 = Russia, India
6 = China
0 = Code Free
This is taken from the original service manual for the reciever
Jan 27, 2008 | Philips LX3600D System
215 people viewed this question
 Grubhead
Grubhead
