Question about E-Machines (308714) Motherboard
Wiring info My girlfriend took the front cover off her Emachines t6410 and unplugged the 3 connections from the motherboard labelled power led, hd d led, and power the are black/white red/white and green/white wires.....where do these little plugs need to connect to on the motherboard
  • 3 more comments
  • Anonymous Jul 12, 2008
    well they r labled as a row of led but which one goes where i tried match colors and nothing happen still can not boot computer
  • emach Aug 26, 2008
    I have a similar situation with an e-machine T2042 motherboard, but there are 2 double pin blocks where the Power LEDis noted with only 3 actual pins. Does the Power connector go on 1st block of 2 pins and leave the next bock with 1 pin open or does the connector go between the 2 blocks over 1 pin of each or simply over the block that has only 1 pin. Is there a site where I can view a T2042 motherboard scematic properly connected?
  • joelukey Aug 30, 2008
    plug power led hd led power s/w
  • Nick Charles Oct 16, 2008
    DOES ANYONE HAVE PICTURE SO I CAN MAKE SURE I HAVE IT WIRED CORRECTLY. DONT WANT TO TURN IT ON TIL IM SURE.
  • lucyball2 Oct 16, 2008
    emachine model t4010 i dont know how to connect the ledpowe,powe hdd wies back up.
Lay out is screened on the Motherboard above the Battery
HD Led pinss 1-3
Pwr Led pins 2-4
Reset pins 5-7
Power On pins 6-8
Posted on Sep 09, 2008
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
Posted on Jun 21, 2008
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
Need where pwr sw and pwr led and hdd led plug onto au31 motherboard
Here is a link for the manual for your au31 motherboard. The diagram explaining the front panel headers is on page 12.
http://www.lurkhere.com/~nicefiles/AU31_manual.pdf
Dec 02, 2009 | E-Machines T3092 PC Desktop
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
Pinout on t6410 gATEWAY CONNECTING POWER BUTTON
Take a picture of your motherboard and then make printed copy. Call the technical service department and give them the make of your computer and model number, also give them the name of the motherboard and its model number with revisions. Ask them to look up the wiring diagram showing the external connector hook-up from the case to the motherboard. Write down the pin connections on the photo. You can share this information with other people who are having the same problems. Remember to always take a pictures of your set up before disassembling the unit. So you can reassemble the unit correctly. These units are so proprietary that it is almost impossible to find this information without their help. Hope this helps you with your problem.
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Proper connection
if u look real close to the pins on the board they will say pwd led and power sw ect ect please keep me posted if you need more help identifying these pins
Aug 06, 2008 | E-Machines eMachines Desktop PC
Power button wiring
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
May 10, 2008 | E-Machines eMachines Desktop PC
E-Machines (308714) Motherboard Logo
317 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
