Question about Whirlpool RBS305PD Electric Single Oven
Where is the thermal fuse located on an electric whirlpool in cabinet oven?
  • Anonymous Mar 31, 2014
    Where is the inline thermal fuse (part 9781691) located for this oven
    Genius:
  • 1,416 Answers
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks,
    Posted on Oct 10, 2010
    • enricogab Sep 16, 2011
      If it is an incabinet electric oven. Whirlpool RBS275PDQ14, where is the location of the fuse. I already replace the bake element and nothing happened, gets warm to touch but that's it.
      The rest of the oven works fine. Please help.
    Where is the thermal fuse located and how do I replace it on Whirlpool double oven GBD307PRS03? Thanks
    The thermal fuse is located on the back of the upper oven to get to it to replace it the oven would need to be removed from the cabinet and the back panel removed ( not fun but what must be done) here is a image of what the thermal fuse looks like.
    GENE
    Oct 15, 2011 | Whirlpool GBD307PDS Electric Double Oven
    After self cleaning the display is blank and door is locked
    Which thermal fuse did you replace?
    There are 3.
    This manual will help you diagnose the oven.
    Thermal fuses are explained on page 3-2.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
    Jul 11, 2010 | Whirlpool RBD305PDS Electric Double Oven
    Well, it won't come on.
    1st check you breaker. If the oven is getting power then it's most likely to be one or more of the thermal fuses. There is one thermal fuse that feeds the control board. It's located in the wiring harness and accessible from the front. The other fuses are chassis mounted on the back or top so the oven has to come out of the wall.
    Jun 26, 2010 | Whirlpool RBD305PD Electric Double Oven
    The oven won't come on. It is a whirlpool electric single oven range
    If the oven is getting power it's probably one or more of the thermal fuses. There is a thermal fuse in the wiring harness that feeds the control board. Accessible from the front. The other fuses are chassis mounted on the back or top.
    Jun 26, 2010 | Whirlpool GBS307PR Electric Single Oven
    Display reads code F03 on Whirlpool oven. Can I
    Hi
    Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
    How do I get into the fuse to change it on my whirlpool GBD307 PDQ7 oven? Where is it located?
    There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
    Enter here to find assembly diagrams and parts for your model.
    Contact the seller by phone if part is not listed on the website.
    Jan 02, 2009 | Whirlpool GBD307PDS Electric Double Oven
    The Oven won't heat up
    the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
    Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
    Whirlpool electric oven problem
    thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
    Sep 22, 2008 | Ovens
    Whirlpool Wall Oven not working
    It is likely the Thermal Cut-Off (TCO) fuse, which for many Whirlpool ovens is located on the back of the unit. Turn the circuit breaker for the oven OFF first. You'll need to remove the trim on the left and right side of the oven (2 screws) and then remove the screws holding the oven in the wall. You can locate it easy enough by looking for the thermal fuse on any of the major appliance part websites. The test is simple enough if you have an Ohm meter, as it will be an open circuit if it is blown. There is only one fuse (normally) so if it is blown neither the bake or broil element will work. There should be a Tech Sheet located behind the control panel which will help, but if you don't feel comfortable doing this call a service tech.
    Apr 02, 2008 | Whirlpool RBS245PD Electric Single Oven
    WHIRLPOOL OVEN
    have you checked your in coming power the clock will work on 110 but it takes 220 for full function zzsbolt yours does sounds like a thermal fuse
    Jan 18, 2008 | Whirlpool RBS305PD Electric Single Oven
    Whirlpool RBS305PD Electric Single Oven Logo
    930 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
