Question about Bose Companion 3 Computer Speakers
Bose companion speakers
I went online last night for the instructions. Follow them to check out everything, nothing unplugged. Still no sound. Thanks, Mahaff
  • mahaff Jun 01, 2008
    Avwrexit, Thanks I plugged in the front and it works. Thanks for the help. I just wanted music. Its boring just to work and have no sound.
  • 47 Answers
Hmmm.. well if you system is like mine it has multiple ports for sound. Try the speaker plug in the front of the machine.. better yet .. to ascertain whether or not it is your speakers or sound card issue then plug some headphones in to the port and see if you have sound. Never forget the basics the sound muted? Open your sound eq application and see if the wave output is turned down.
Keep me posted!!! and Good luck!
Posted on May 31, 2008
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
My speakers make a sound when everthing is turned off
what you are probably hearing is a form of mains interfearence. the only to stop the sounds coming out is to unplug them from the mains.
Best of luck
Oct 24, 2011 | Bose Companion 2 Computer Speakers
My husband purchased Bose compnion 5 in Singapore last December. He tried it last night but the right side speaker had a very soft sound compared to the loud sound from left side speaker. How do we fix...
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 31, 2011 | Bose Companion 5 Multimedia Speaker System...
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
Crackling sound
That sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
May 01, 2009 | Bose Companion 3 Computer Speakers
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Dec 26, 2008 | Bose Companion III Computer Speakers
Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Apr 10, 2008 | Bose Companion 3 Computer Speakers
Bose Companion III speakers
I have the same problem but I can't figure out how to fix it
Mar 26, 2008 | Bose Companion III Computer Speakers
Bose Companion 3 Computer Speakers Logo
138 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
