Question about Cameras
Zoom out of focus error message E:61:00 - Cameras
  • beserminr Oct 09, 2010
    sony handycam model # DCR-DVD108
  • 10,594 Answers
Let me know model and brand of your camcorder/ camera to provide you helpful info.
Thanks.
Posted on Oct 09, 2010
  • Shahid Electronics
    Shahid Electronics Oct 09, 2010
    Sony DCR-DVD108
    E:61:00 is an error code that indicates problem with Zoom Motor in lens assembly.
    Can you take apart camcorder safely? If yes then go to lens assembly and remove zoom motor assembly to get it release and put it back so it can freely move focus lens to get correct focus.
    Let me know if you have additional question.
    Thanks.
E:61:00 error
E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
· Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
Here is the first alternate method (AVI format)
Here is the second alternate method (AVI format)
Good luck.
May 03, 2011 | Cameras
When i turn on the camera, it gives me an error message: the lens cover might be closed - E61:11
The abnormalities in initialization of the focus lens and the abnormalities in initialization of the zoom lens occurred simultaneously (FOCUS OR ZOOM SECTION NOT WORKING PROPERLY)
Mar 29, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Fujifilm finepix a820 zoom error ... i turn the camera on and it wont focus... message on lcd screen is zoom error. it will not take picture and when i turn it off agan the zoom bit wont go back inside
    This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
   Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
    Thanks for using fixya.
Oct 28, 2009 | Fuji FinePix A820 Digital Camera
F01 error on playback or recording - Panasonic NV-DX100
Panasonic JVC Description
F01 No Take-up reel rotation
F02 E03 No Supply reel rotation
F03 E02 Mechanism has not unloaded to the eject position
F04 E01 Mechanism has not fully loaded to the stop position
F05 E04 Rotation of video head has stalled or to fast
E06 Tape drive motor is not rotating or stalled
F31 Data transmission error
F51 Focus motor is not functioning, No focus
F52 Zoom motor is not functioning, No Zoom
U10 Dew sensor has detected condensation or failed
U11 Video heads have been detected as dirty or failed
Matti Knuutila mattik1999@yahoo.com
Jul 11, 2009 | Panasonic Video Cameras
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
When I try to take a picure it says focus error When i try to take photo, 'focus error' message flashes on the screen.
you can try 'knock' this to try free it but the motor that controls the focus is probably siezed.It's fairly common to get zoom/focus error with several types of compact camera, I think the cause is probably being switched on while in a case.
I've dismantled one down to components to find it was the motor itself and been unable to do anything!
If you want to sell it for parts, I'm after one - email me "a.r.jardine@swan.ac.uk"
Mar 11, 2009 | Fuji FinePix F610 Digital Camera
My camera is showing the error code E:61:00
On Sony equipments this error code seems to be dedicated to focus and lens errors. You may have either some dirt or anything like this inside the lens or focus mechanism, or a broken mechanism (any drop of your camera lastly ?).
If you can open it properly, you should check for "foreign body" inside the mechanism (focus and zoom mechanism, but but code 00 means focus normaly).
Jan 16, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
