Question about Palm 3330WW Bluetooth Headset
Where can I get a charger for a bluetooth palm headset 3330WW?
Can I replace the battery in the plantronics Discovery 650?
They are available on Amazon.com... http://www.amazon.com/Plantronics-Discovery-665-650e-Headset/dp/B00HYGMW3G%3FSubscriptionId%3DAKIAILSHYYTFIVPWUY6Q%26tag%3Dduckduckgo-d-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB00HYGMW3G
Jul 08, 2014 | Palm Plantronics Discovery 650/ 655...
How do I get my 3330WW to sync with my iPhone4?
While Your Phone is searching for new devices and in listening mode:
Press the Headset-Power-On and keep pressing until Your Phone/iPhone recognizes the Headset.
The Palm 3330ww will be locked on with "Palm Headset" as a new Bluetooth-Device.
Should work with any Phone.
Aug 15, 2010 | Palm 3330WW Bluetooth Headset
Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
May 16, 2010 | Jabra BT350 Bluetooth Headset Headset
I cannot get it to connect. My Palm Centro recognizes it, but says that is unable to connect even though it has done so in the past.
Try disconnecting the bluetooth device then turn the bluetooth off then hold the power button untill the bluetooth shows a solid red light then try connecting the bluetooth between your palm and the bluetooth device hope this helps
Oct 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Car charging Bluetooth Motorola h-500
Yes, the car charger will work fine, just make sure that any time you use a car charger, remove your device when it is finished charging. If you leave your phone or bluetooth headset on the car charger, it will continually force power into it and over time reduce battery life.
Dec 27, 2007 | Motorola Mobility Bluetooth Hands Free...
Palm 3330WW Bluetooth Headset Logo
29 people viewed this question
Top Palm Radio Communications Experts
ka4iup
ka4iup
ray gallant
Are you a Palm Radio Communication Expert? Answer questions, earn points and help others
