Question about Sewing Machines
I have a Nelco sewing machine and i forgot how to put in a new needle adgilbert40@comcast.net thanks!
    Problem Solver:
  • 8 Answers
There should be a screw down by the needle, by the presser foot. Unscrew that button and remove the old needle. To replace that with a new one... there put the top of the needle into the needle hole. There will be a flat side to the needle and a rounded side. The flat side goes in the back. Once you have the needle in its position, tighten the screw to hold it in place. Let me know how it goes and if that fixes it.
Posted on Oct 09, 2010
First Thread breaks on nelco 928 why?
Remove all the threads.
Replace the needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify each thread is in the correct thread path.
ALWAYS THREAD each in the order specified or you will continue to have problems--for a lot of machines, the order is Upper Looper, Lower Looper, then needles.
Check the tension on that particular thread--too tight, it will break.
Breaking thread after about an inch usually indicates it is mis-threaded--a guide has been skipped or threaded out of order or the thread may be wrapped around something.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Sew What Up View thread Help Needle thread keeps breaking
Nov 21, 2017 | Sewing Machines
I need the manual for a Nelco F600. Do you have it or know where I can get one. I was given a machine but think it has been in storage for a long time! Need to oil and check it out.
A manual for a similar model would be a benefit. Most machines operate and thread the same. Yes, you should definitely clean and lube your machine before trying any sewing. Tri-Flow Synthetic Lube from the hardware store is a good product to use because it does not dry out and turn to glue over time.
Nelco sewing machine manual free
Wheel on right side that controls the needle up and down is very tight...
Nelco Sewing Machine
FWIW, I inherited a Nelco J28 and it is the toughest machine in my arsenal. I repair horse equipment with it. The stitch quality is not the best, but it certainly sews most anything thrown at it. The only issue I have with it (and it is my issue, not the machine's) is that it has a side-loading bobbin which means the home position of the needle is also on the left instead of the middle. Having always used a centered needle makes using it seem somewhat unnatural. However, your machine appears to have the front-loading bobbin and centered needle.
May 16, 2017 | Sewing Machines
What's wrong with my Nelco 234F sewing machine. When I try to sew, the machine gets jammed and the thread is all tangled around the bobbin.
Install a brand new needle.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Generally, the top tension should be set at the midway point and then tweaked for your particular machine.
If you continue to have a problem, the machine probably needs service.
May 09, 2017 | Sewing Machines
Hello I have a nelco sewing machine but I have no clue how to sew with it I am a mixed media artist and now I want to incorporate sewing in my art please help me thank you
Before we can help, we need to know the model.
Perhaps this will be helpful:
Nelco JA 38 Sewing Machine Threading Diagram
FWIW, I have an old Nelco J-28 that was passed on to me by someone who started quilting with it and advanced on to a career making wonderful creatively designed scenic quilts. It is a basic machine with straight stitch and a few zig-zag stitches. It's a tough metal mechanical machine and has been used to repair horse equipment (fly masks, etc.) and upholstery. The only thing that is perplexing to me is that it is a left needle position machine, ie the bobbin loads on the left side, the needle faces the left side, and the needle home position is on the left side and swings from the left to the right. All my other machines are center needle position so it takes some adjustment whenever switching to the Nelco--but that is a personal thing and in no way reflects on the machine and its usability. The good thing--since it is a mechanical machine, it can be maintained with frequent oiling using fresh good quality sewing machine oil and regular cleaning.
The best advice ever provided--Always Raise the presser foot when threading the upper thread and make sure the machine is threaded correctly.
Jan 03, 2017 | Sewing Machines
How do you fix a left of center needle on a Morse Apollo 6500 sewing machine?
Is this machine new to you? Some of the older (but goodie) machines have a needle that defaults to the left. (I have an old Nelco that has this--great machine, just takes getting used to sewing with the needle in that position.)
Otherwise, I suspect the machine needs a thorough cleaning and oiling because the old oil may have dried out and is causing it to seize.
Jun 08, 2017 | Sewing Machines
How to thread the Nelco A2?
To find a user's manual, search the internet for:
Manufacturer + Model + the word "Manual"
Search YouTube videos for threading tutorials:
Nelco Zigzag Sewing Machine Final Test Demonstration Video
VINTAGE ALL METAL NELCO MODEL 400 2 SEWING MACHINE
NIFTYTHRIFTYGIRL Vintage Nelco model 250 sewing machine
With your Nelco, be sure that you install the needle properly. Frequently, Nelco machines take the needle with the flat side facing toward the throat of the machine--not toward the read like most other machines. The upper thread will thread through the needle's eye from the left toward the right. They also are a left needle position machine--meaning, the standard position of the needle when sewing straight stitch is at the left side of the presser foot, not center like most other machines.
Nov 15, 2015 | Sewing Machines
My mother"ssewing machine willnot pick
I saw Nelco on this website http://www.sewusa.com/Sewing_Machine_Manuals/Nelco_Sewing_Machines.htm
purchasing /obtaining a manual is always very helpful when working with a sewing machine.
However, simple stuff to check, is the needle in the right way, with the scarf (groove) to the back?
Is the needle new and the right type of needle for this machine? Sorry, I don't know a lot about Nelco however, most machines use 130/705H system needles, but there is always the exception, especially with something 40+ years old so it pays to check it out.
And lastly timing, the needle needs to be down at the lowest point as the rotary hook comes around to catch the thread. If this isn't happening, then it could be that the timing is out on the machine. It's never happened to me but it can happen. But I'd suggest you try changing needle, check threading path and bobbin firstly.
Good luck.
Apr 10, 2011 | Sewing Machines
Sewing Machines Logo
251 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
