Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
Ping problem please send mail to this e-mail adress babumitroy@yahoo.com comfortable IP address and hoe pounch cats 5 cable with rj45 connector
  • 86 Answers
What ip you need
Posted on Jun 07, 2008
Modem conneced poperly, LAN is working & modems admin page can be open, but cannot be connected to the internet
Hello, If you want to connect through cable use cross connectionwith RJ45 For your main pc LAN setting >R click on my network >properties>R-clickon LAN modem>properties />select internet protocol>properties>useset for manually IP>
IP address=10.0.0.1
subnet =225.0.0.0
for ping =run>10.0.0.2 -t
Another one will be same process>
IP address=10.0.0.2
subnet =225.0.0.0
default gate way=10.0.0.1
now ping >run type ping10.0.0.1 -t
R click any folder now ,properties>sharing>just share>tic on share thefolder on my network>can change any name for folder,
Hope it will help you.
Jan 26, 2011 | Computers & Internet
Zebra 140XiII - cannot print via Ethernet cable - Windows status monitor shows status as offline. I Installed correct drivers? what is the secret for connectivity!? Greg
check if IP adress, subnet mask and the gateway are correct on the printer setings.
Try to ping the IP address from the START-Run...(write CMD) and write ping IP adress.???.???.???.???
check if had responce.
Sep 15, 2010 | Zebra 140Xi II Thermal Printer
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
R50 will not renew ip address
1. Login to router first and verify that the router with the rj45 cable.
2. Go to the DOS window and then type "cmd" then type at the prompt "ipconfig /all". this will show the network connections but look at the wireless connect and the ip and MAC address.
3. Disconnect from the RJ45 ( Ethernet cord) then reboot the PC or laptop.
4. check laptop for IP address from router.
5. At the dos prompt do a ping >> www.yahoo.com
example: ping www.yahoo.com
Aug 07, 2010 | IBM Computers & Internet
Added a Belkin USB Wireless adapter to my desktop. Seems there is a wireless connection from USB to D Link but desktop can not see Internet.
Apr 25, 2010 | D-Link AirPlus DI-524 Wireless Router
How do i get connected to another local computer with wire
you need either a "crossover" cable or both plugged into an ethernet switch, with network settings the same but i.p. addresses off by 1 digit. eg. 192.168.1.3 on computer "a" and 193.168.1.4 on computer "b".
Oct 25, 2009 | Computers & Internet
Not getting internet. Status shows strong connection and sending but limited receiving
Hi, Please confirm if you are able to go online when connected wired to the router. If yes then please perform the steps below on the concerned computer and mail us the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here. Also, mail us the same IP configuration.
C. Type ping 4.2.2.2 and hit ‘Enter’. Mail us the text that you see just below this command.
D. Type in ping yahoo.com and hit ‘Enter’. Mail us the text that you see just below this command.
also, please specify which operating system is being used on the computer?
The answers will help me resolve the issue at the earliest!
Jul 17, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
How do i get my IP adress for my Netgear router.ISP=tiscali
Check this link for your ip address lookup. If you cannot by clicking the link then here it is.
http://www.people-search.com/register-options.php
Apr 25, 2008 | Computers & Internet
Automatically ping and trace disabled after PBR
please add me on yahoo messenger or mail me , let me know when ur online , my id is samrat101@yahoo.com and we will be able to resolve it sooner,,, mails takes time.
Samrat
Feb 20, 2008 | Computers & Internet
Edimax br-6504n
see
http://www.fixya.com/support/t235287-edimax_6504n
Oct 27, 2007 | Computers & Internet
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
238 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
