Question about Vacuums
Have a 3 year old Pfaff Creative Vision. Has less than 14 total sewing hours on it. Has had issues in the past. Breaking needles, wouldn't stitch out designs in acceptable manner(badly distorted looking) breaking needles repeated, now it is changes stitches on its own, then went to sewing the same stitch but isn't sewing it consistantly. I have taken it back to the same professional to repair each time. Can thhis machine be repaired??? Should I trade it off and get another, this isn't my first choice by the way? I just want a machine to do what it's supposed to when I want it to. Please repond asap.
  • haworthlois Oct 09, 2010
    Any reccomendations on which line of machines has fewer issues and is user friendly? Bernina has poorly written manuels to understand but very nice embroidery work. Am not really familiar with any other brand. Any suggestions?
    President:
  • 2,777 Answers
It sounds like this machine has some kind of fault in it for sure. It can be repaired again, but will likely need to be repaired again after that - down the road. Personally I recommend you just get rid of this unit and go for a different model. You can sell it on ebay to at least get something out of it. Just list it as accurately as you can, naming this issue.
Thanks
Tim
Posted on Oct 09, 2010
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    Bernina is my recommendation really, they are top notch machines and the amount of help and documentation online is amazing for sure. For example any questions or problems you can check with:
    http://www.berninacentral.com/forum/
    It's an online community for the machines, and there are many more where that came from. The community support is great on them. And the warranty is very good from Bernina, best of both worlds...
    Tim
Singer Stylist 7258 will only sew backwards and is only making holes...no stitches!
this link is for the manual go to page 32 ,it sounds like you have it on button hole stitch witch goes in revers, you need to press button hole off switch.
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Oct 23, 2012 | Singer Stylist 7258 Electric Sewing...
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
What needle and thread would you use for sewing marine vinyl when using a pfaff 130
I have heard Pfaff 140 needle with V-92 or V-138 thread is the way to go with marine vinyl.
I hope that helps.
May 02, 2010 | Vacuums
While using the pin stitch , the machine has started skipping stitches, knocking loudly, the top thread is breaking, sometimes thread knots up on the underneath side. I have cleaned bobbin area, changed...
Please go through the link given bellow to have the resolution to your problem...
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 27, 2010 | Vacuums
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
