Question about GMC Vehicle Parts & Accessories
My 2000 Yukon Denali will not start. I suspect the security system because there isn't a problem with the battery. Turn the key and nothing happens. Can I reboot the system or is this possibly just an ignition switch issue?
    Genius:
  • 1,035 Answers
Hi. You can reset the security system by detaching the negative port of your battery and then put it back. You can test also the ignition if it is bad by turning the headlights on then turn the key to start position. Headlight should go dim if the ignition is good. If nothing happens to the headlight when you turn the key to start position then you have a bad ignition.
Posted on Oct 09, 2010
I have a 2000 GMC Denali. I had the battery unhooked for about a week, because there is a draw on the battery somewhere. I then rehooked it up and now it won't start. When you get in the truck the...
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:4
Aug 12, 2011 | 2000 GMC Yukon Denali
2000 Yukon XL wouldn't start. We replaced the battery and it still won't start. The lights come on but when you turn the key it does nothing. The security light flashes could this have something...
Those has every thing to do with it. You'll find the answer you need though this link. Comment back if you have questions http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jul 25, 2011 | 2000 GMC Yukon Denali
I have a 2000 Yukon Denali and the alarm system will not alow it to start at times.....What should i do whwn this happens or how can i prevent this from happening
According to my lists, 2000 Yukon has a Passlock 2 anti theft security system. This means that the key literally has a transponder in it that sends a radio signal to the ignition. The ignition/lock cylinder then sends a signal to the TDM (theft deterrent module) which then reads the signal and allows your truck to start. If there are any communication breaks, the truck thinks its being stolen and goes into anti theft.... Read up on this link. There might be an option for you. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 05, 2011 | 2000 GMC Yukon Denali
I bought a wrecked Denali hooked the battery up and everything just keeps flashing is there a reset for the system or is this another problem
sounds like the security,if you got a key fob,use it (assume u would have done that)
Try locking then unlocking the drivers door from the outside with the key,should turn the system off
Nov 19, 2010 | 2003 GMC Yukon Denali
Removed/charged @ reinstalled battery, security light & security system won't shut off,key won't start car or even turn over
Because you disconnected the battery you have set the security system on and it will have to be reset. Try putting the key in and leaving it in the on position for 20-30 minutes, shutting truck off and then try restarting. Short of that you may have to call the dealer.
Sep 24, 2009 | 2001 GMC Yukon Denali
2000 yukon denali will not start
I had problems with my remote button, with battery fully charged turn on key for ten second, turn key off un-hook positve side of battery, re conect turn key to on postion then try to start, it worked for me I have a 2003 denali yukon XL, the motor would fire then stop.
Jul 29, 2009 | 2000 GMC Yukon Denali
2007 yukon xl battery dead recharged battery will not start no security light no gages work when you turn the key on. try to start the engine nothing happen like the security system shut down. can you...
We had the same issue with our 2007 Yukon Denali XL. Died on us twice after sitting for short periods of time; once we watched a DVD with the engine off and battery died within 10 minutes. The dealership kept it overnight to troubleshoot why the battery died so quickly. They said the radio was "pulling" too much from the battery. (They supposably fixed it) But again a few days later the battery died again after sitting overnight. We brought it back to the dealership and they brought in a GMC "expert" to replace the entire DVD/CD/Navigation system. They also replaced our battery with a much larger battery, similar to the ones that GMC puts in there diesel trucks. They had our Denali for 5 days, but it appears to be fixed now.
Getting it fixed correctly wasn't without headaches, but it was all covered under warranty, including the battery. And they are updating the nav w/ the new edition disc as well for no charge.
Apr 13, 2009 | 2007 GMC Yukon
2000 gmc yukon denali wont start i think because of the security
you have a bad ignition switch but if you turn key on for ten minutes until the light stops flashing then turn off key then try to start this should reset the security system
Mar 19, 2009 | 2000 GMC Yukon Denali
Vehicle Parts & Accessories Logo
261 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
