Question about Acer AL1717 17" LCD Monitor
Normally, when the monitor is switched on, a blue screen is shown momentarily, with 'acer' right in the middle, before it shows the image that the computer is sending. But now, the screen does not show either. Now, the screen has a white strip on the left, followed by a yellow strip parallel to it [each an inch to two wide]
    Novelist:
  • 112 Answers
It sounds like either a bad signal input , possibly from a loose plug on the cable from the PC or bent pins on the plug / the video graphics card in the PC/ or the settings on the monitor need adjustment. Use the OSD (On Screen Display)
First check to make sure both ends of the cable from the PC to the monitor are not damaged and are seated good & tight.
If those are fine then unplug both cables from the monitor & leave unplugged for 10 minutes or so to see if the screen has an automatic reset.
If that does not work then use the monitors OSD (On Screen Display) to adjust to default settings. If that does not work, plug the monitor into another known good PC.This will tell you right then if its the monitor or "Your" PC.
__________________________________________________________
Here is your manual if needed
http://www.retrevo.com/support/Acer-AL1717-Monitors-manual/id/719ag107/t/2/
Posted on Oct 09, 2010
How do i fix white screen on my kav60 acer aspire one
The KAV60 is also the AOD250.
Netbook OFF, monitor OFF, connect an external monitor to the netbook's VGA port.
[You can use a VGA monitor. Looks like a small TV.
This is an example of a VGA port,
VGA connector Wikipedia the free encyclopedia
Note* VGA port doesn't have to be blue in color ]
Turn the monitor on. Turn the netbook on.
If there is no image shown on the external VGA monitor, press and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(The F5 key is the Display Toggle-Over key)
No image on external VGA monitor?
Hold the Fn key down once more, and tap again on the F5 key.
Still no?
Problem is internal in netbook. Probably graphics chipset soldered to the motherboard.
Replace motherboard.
Image shows on external monitor?
Problem is with Video Cable or laptop LCD screen.
MOST of the time it's the Video Cable.
The Video Cable connects to the motherboard, in an area under the Keyboard. It then routes up under the left Hinge, and into the Display Panel.
Inside the Display Panel it then connects to the LCD screen.
With frequent opening and closing of the netbook, the Video Cable can be pulled on. This can cause damage to the Video Cable.
(Stretched/broken wires inside the sheath of the cable)
And/or it can cause the connection at the motherboard to be loose, and/or at the LCD screen.
Example of Acer Aspire One video cable,
For ACER Aspire One D250 LCD Screen Cable DC02000SB10 KAV60 New
You can remove the Video Cable, and check it's continuity with a multimeter, or if the cost is reasonable to you simply replace it.
8 to 10 dollar video cable is not the problem? Then problem is the LCD screen itself.
My money is on a loose video cable connection, or damaged video cable.
For additional questions or to have me clarify/simplify anything in my solution, please post in a Comment.
Regards,
joecoolvette
Jan 15, 2015 | Acer Computers & Internet
My computer PC of SAMSUNG Sync Master753DFX is shown "control/Uncotrol" lock is appears by itself and shown more than 5 - 10 sec on the screen and smack in the middle if the screen and also when...
the button of your monitor must have have a problem already. I would suggest you bring it to a technician to check on those buttons. It must be grounded.
Sep 10, 2011 | Samsung Computers & Internet
I have an Acer X193W....looking into the blue light on the power button it seems "dark" at the middle of the power switch light.....is this a burnt out light or do I see an internal part that is...
You are right. You are seeing an internal part that is in the middle of the light.
Specifically, the light is an LED (light emitting diode) the part you are seeing is the stand on which the actually silicon chip is mounted.
Jun 22, 2011 | Acer X193W LCD Monitor
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
When I turn my monitor on, the screen shows the desktop momentarily and then goes black. If I turn it off and on a couple more times, the desktop will stay on and function normally. Where is the likely...
Try the monitor on another computer, to check-out the monitor.
Does the POWER lamp on the monitor stay on when the monitor goes black? If so, then the monitor probably is OK.
Try a different monitor, to trouble-shoot the video-card.
May 28, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
My acer 9300 when switched on shows a blank screen (black with some faint white back ground) but the process of starting windows goes normally coz i can view this when connected to a monitor whats a miss ?...
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 25, 2009 | Acer Aspire 9300 Notebook
Blue dots in the middle of the screen
The image processor must be getting old and worn out. Call Epson or go onto their website and see if it is  a dDIY project or if you will ned to send it in.
Apr 27, 2008 | Epson EMP S1 Multimedia Projector
Acer AL1717 17" LCD Monitor Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
