Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
Posted on May 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Poor picture Hi There, I have a Samsung LE32R74BDX which I purchased in September 2006. The picture has deteriorated recently particularly when it is first switched on, and appeared lifeless and dull, and would always improve within 1 to 3 hours. I had an engineer come out this morning and he identified the following:- 1) The Energy Saving feature was set at high and he turned it to Off. 2) He also adjusted the TV to Dynamic Mode from Standard. Both of these adjustments have improved the picture dramatically, but I have still some concerns which the engineer could not answer. Why is there a Energy saving feature if it cannot be used and must be switched to Off? I have also read that using Dynamic Mode is not good for the TV and can cause screen burn. I would welcome any thoughts and comments. Many thanks Michael
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on May 30, 2008
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564562
Points
12312
Dynamic mode will give you a brighter picture. The energy saving mode runs the lamp at a more efficient level that saves energy at the cost of a slightly darker picture. Based upon your description, I'd guess that the lamp is nearing the end of its useful life. Plan on changing the lamp soon. When you do so, place the set back to standard mode and energy saving.
Dan
What is TSB 7/2006
TSB 7/2006
Subject/Concern: Hesitations; Poor or no start; Deteriorated fuel economy; Diagnostic trouble codes (DTC) P1412, P0490 and P1335 stored
Model: Focus C-MAX 2003.75 (06/2003?¿½) Build Date: 14.02.2004-01.03.2006
Build Code: 4R-6S
Assembly Plant: Saarlouis
Engine: 2.0L Duratorq-TDCi (DW) Diesel
Focus 2004.75 (07/2004?¿½) Build Date: Up to 01.03.2006
Build Code: Up to 6S
Assembly Plant: Valencia
Markets: All
Section: 303-08
Summary
Should a customer express concern about one of the following:
* hesitations,
* poor or no start,
* deteriorated fuel economy,
and upon investigation diagnostic trouble codes (DTC) P1412, P0490 and P1335 are stored in the powertrain control module (PCM), the probable cause is a sticky exhaust gas recirculation (EGR) valve.
To rectify this concern, a new EGR valve with a stronger EGR valve motor and revised PCM calibration should be installed.
We have a Samsung LE32R74BDX EU HD TV We have just
A manual is at;
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=101&prd_mdl_cd=LE32R74BDX%2FXEU&prd_mdl_name=LE32R74BD&srchword=LE32R74BDX%2FXEU
You can download a number of files at this location. The files are in PDF format so if you need the adobe reader you can get it by clinking on the link at the bottom of the page.
5-year old 32 in. Samsung which only displays a fuzzy gray image
It sounds like the T-CON board problem, you can try reseating the connector first, the board is mounted under the metal shield which sometime can be difficult to get to.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
The projector is approximately 4 years old & on average runs for about 60 hours per week, 40 weeks of the year. After fitting a new lamp last October & resetting the projector, the image is still...
Additional information is required for us to assist. Can you better describe what you mean by "poor image"? Are the colors separated? Is the picture out of focus? Are the colors wrong?
Please describe the picture or post a picture of the screen if you can.
Thanks,
Dan
2helpful
I need the manuel of the quinny buzz 2006 that I bought second-hand recently (pdf or scanned formats would be the best)
If you visit www.quinny.com, you should find the information you require.
If not, I have I 2006 September manual that I can email to you on a pdf format, not quite sure of how to do that via this site tho.
I hope that this helps.
Sep 07, 2009 • Baby Gear
Vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Poor resolution
Try to change the screen resolution on your computer right click on the desk top properties then settings tab. If this does not help try adjusting the video options on the tv like contrast and such.
Multi Zone code Samsung 5600 DVD VCR Combo
Try this site:
http://www.videohelp.com/dvdhacks/samsung-dvd-v5600/7031#26074
Particularly the entries from:
Region code hack posted by Anthony Green, September 10 2006:
And
Region code hack posted by ZoidsGodzilla, November 22 2006:
Good luck
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
