Question about Poulan Pro 22inch 625 Series Briggs Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower (CA Compliant) PR625Y22RPX
PP 22inch 625 series 190cc - What Gas/Oil mix should i be using?
  • 755 Answers
I think your mower has a 4 cycle engine. That means the oil goes in the crankcase and the gas goes in the gas tank. No oil mixing needed! If you look at the top of the mower you should see two caps. Each one will be marked with what goes in them.
The oil should be 30 weight non-detergent oil. Available at your local car parts store or Lowes or Home Depot.
Gas is just plain old pump regular.
Posted on Oct 11, 2010
Acts like it's not picking up gas. will run as you spray into carb.
Dirty carb. If it has a fuel bowl take it off and clean it out and clean the fuel jet that has little holes in it. I use an air compressor or a real fine wire.Try this before tearing it apart.
Mar 15, 2015 | Poulan Pro PR625T22RP 22inch 190cc Briggs ...
Oil specifications Type and Weight
Here is a number to brigg an Stratton 800 444 7774 they will have info for u
Jul 08, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Does 2stroke go in gas
If you are referrig to 2 stroke oil, the answer would be no. Generally speaking 2 stroke oil is mixed with gasoline at the appropriate ratio and is used in gas powered weed eaters and chain saws. A lawnmower for the most part is considered a 4 stroke motor. You only need to use gasoline in the tank. Make sure that at the end of the season the gas tank is pretty low or even allow it to run dry. This is simply to avoid the harmful deposits that old fuel can cause to gaskets. If emptying of the gas tank is not easy, you can add fuel stabilizer to ensure that the fuel is usable for the next season.
Jun 30, 2014 | Poulan Pro 22inch 625 Series Briggs ...
How do I replace the starter spring/coil on my self propelled scottts lawnmower
There are some wonderful videos that guys have produced up on Youtube. Here's a good example of one. The guy is doing an old Honda engine, but they're pretty much all the same. Once you've done one, you get the idea and can do pretty much any of them. Good luck to you; I hope this helps:
http://tinyurl.com/3hyyauc
Apr 23, 2011 | Poulan Pro PR625T22RP 22inch 190cc Briggs ...
Where is the oil plug on a Poulan Pro 625?
Hi ca rishell
The oil drain plug is under the mower, look for the pipe plug in the engine housing, be sure to remove the spark plug wire before working near the blades as a safety item...
Free Answer, Please rate me
Apr 16, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Just looking for the type of oil I need to use for my poulan pro 625 series
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I have a Briggs and Stratton 625 series mower that will start but not run for more than 30 seconds. I was told to change the spark plug. I noticed that there is oil on the spark plug and in the hole where...
Sounds as if the problem is in the fuel system. When water develops in the tank, the weak fuel cannot keep the motor running. Use a solution for removal of water condensated gas tanks.
Mar 12, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Poulan Pro 22inch 625 Series Briggs  Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower (CA Compliant) PR625Y22RPX Logo
328 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
