Question about Singer 2638 Mechanical Sewing Machine
I just got my mother's machine out and the needle will not go up and down? i never learned how to run this machine before she passed away so i have no one to ask how to run this machine! mom has been gone for 8 years and this machine has not been used in all that time.
    Problem Solver:
  • 8 Answers
Can you manually turn the nob to get the needle moving? If you can, it may just need to be cleaned and oiled. I would start by cleaning the bobbin case area and then open up the front enclosure - that sits over where the thread is threaded through the machine. Make sure there's nothing obstructing the parts. Sometimes lint gets in there. Then let me know if that works or not
Posted on Oct 09, 2010
User guide
from the cotton holder you run the thread across to the thread tensioner you pull the thread through this then you thread it through the hole in the little arm that goes up and down with the needle you then bring the thread down to the needle passing it through the holder at the top of the needle then you thread the cotton through the needle make shore the needle is in the right way this should work
Aug 31, 2013 | Sew Pro ZZ401 Sewing Machine
I have a really hard time getting the needle to thread.l I cannot manually pass the thread through the needle eye: the eye is just too tiny; and I cannot even see the hook part of the automatic threader...
I have that machine, and am wondering if your needle has a burr on it, try a new needle, #11 or #80. You may also have no hook in your automatic threader to go throught needle eye. My first automatic threader was defective, no wire to go through the needle to catch the thread. Take a magnifying glass and look when you change your needle and watch when you pull your threader down, do you see a really fine wire come through the needle eye? If, not yours is defective because it has to pull the thread into a little loop for you to pull your thread through it after you release the lever quickly, Mine was a Singer and they sent me a new one right away, Brother will do the same for you, I am sure. Another thing you can do is go to your dealer and have them inspect it, I went to JoAnn fabrics and that is how I learned that I was not crazy, it was the machine,
Apr 20, 2011 | Brother CS-6000
How to thread the singer cg590 sewing machine??
First, be sure your bobbin is in correctly, place it with the thread running counter-clockwise (the tail will be off to the left), and drop it into the bobbin case. Pull the tail toward you and make sure it catches on the silver catch closest to you by pulling to your left then away from you (toward the feed dogs). You should now feel some tension on the thread, this is good.
Be sure the presser foot us up and the wheel is turned so the needle is at it's highest point (neutral), then put a spool of thread on the spool holder (behind the machine above the motor) with the thread catch (a little notch) to the right as you put it on. Put on the thread holder (a plastic donught that holds the spool in place). The spool should not move but the thread should come off of it freely.
Bring your thread through the plastic catch on the back of the machine (near the center) by passing it underneath and pulling upward and to the rear. Pull it to the front over the top of the machine and pass it through the bottom of the small metal holder (not the round part, that is for winding the bobbin). Bring it down in front of the machine to the tensioner, passing it around the bottom of the tensioner then pulling up so that the tension is engaged. Don't worry if you don't feel tension, that's normal if your presser foot is up and needle is at the top. Pull the thread up to the top of the machine and through the receiver then down toward the needle. There is a double loop just above the needle, thread through it then thread your needle front to back.
Be sure to pull up your bobbin thread and hold both threads as you start to sew.
Feb 22, 2011 | Singer CG590 Mechanical Sewing Machine
Needle goes through fabric but is not picking up bobbin thread to complete stitch
Check to make sure the needle is oriented properly. The flat side of the needle should face away from the bobbin. The thread should pass through the needle from the bobbin side.
~<Ray>~
Oct 30, 2010 | Kenmore Sewing Machines
Promblem with an industrial overlocker. need information
DC x 1 should be your needle type.
Try this company for your manual:
Juki MO-2500 Parts - MO-2500: Sewing Parts Online www.sewingpartsonline.com/...ewing-machine-parts.aspx
An Online Juki Parts Superstore, We also supply MO-2500 manuals, presser feet and accessories. Fast, free shipping over $75.
Jul 02, 2017 | Juki MO-623 Mechanical Sewing Machine
Cannot get the bobbin thread to come up with the top thread
1. Make sure the needle is up in the machine all the way.
2. Make sure the flat side of the needle is facing the rear of the machine
3. Only turn the handwheel on the side of the machine towards you, never away from you.
4.Double check your threading of the top of the machine.
5. Also make sure your using the proper needle, your machine takes the most common needle on the market but some look like it and are shorter or longer and wont work properly. Also make sure your not buying needles for a singer serger.
Oct 07, 2009 | Euro-Pro 473
Sticks
Sounds like the machine is in need of lubrication or a thread jam in the hook raceway. Remove the thread and the bobbin case.and, if you can, the top cover. Place a drop of oil on any joints that move. Be careful not to over oil, as it will drip on your fabric.
Jul 12, 2009 | Sewing Machines
Inherited a Huskylock 430 from my mother
Your serger uses the Needle system DBX1 or BLX1. The needles you use in your sewing machine will not work. The eye of the needle faces front to back. The proper needles won't have a flat spot at the top of the needle so you have to be careful on putting them in the serger. You will notice a "groove" on the front side of the needle that runs up and down the length of the needle and a cup like groove on the lower rear of the needle. Long groove forward, small groove backward and you should be sewing!
Jun 12, 2009 | Husqvarna Sewing Machines
Timing is off on my Pfaff 2140/2170 machine.
Basically on any sewing machine to time it you will need to separate the two gears that drive the hook. Usually loosen the set screws that attach the gear to the shaft and separate them.
Time the hook first. On center needle position, set the hook so that the point is behind the needle when the needle bar has risen about 2.5mm.
2) Set the needle bar height. Choose the needle position which is the last for the hook to pass.
(Left on most machines, right on older Vikings) At this point, place the point of the hook behind
the needle and set the needle bar height so that top of the eye is just barely below the tip of the
hook.
3) Check feed timing. Set the stitch length to the longest stitch. The needle should enter the
fabric just as the teeth drop below the surface of the plate.
Dec 14, 2008 | Sewing Machines
Singer 2638 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
