Question about Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641
Leaking tank - Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641
Same problem Leaking unit!... and also saw issues with the thin rubber hose.. other listed that their hose melts!!
Posted on Nov 23, 2010
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
41vr50 leaking at the top connnections
Copy following link for troubleshoot resources:
http://waterheatertimer.org/Leaking-water-heater.html
Replace rusted tank
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Prevent rusted tank.
If nipples are leaking, and they did not leak before, then tank has most likely rusted out and needs replacement.
Cause for rusted tank is depleted anode rod.
Inspect and replace anode each 1-3 years.
http://waterheatertimer.org/Replace-anode-rod.html
Oct 23, 2012 | Water Heaters
My Rheem Electric water heater is leaking from around the side of the tank above the lower element.I can not find the spot exactly. What can I do to find the spot where the leak is coming from?
You can put hand on side of tank and feel for warm spot.
Tank is most likely rusted out and needs replacement.
If tank leak is welded, the rest of tank is still rusting and can rupture under pressure.
Open following links for troubleshoot walk-thru.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Jul 31, 2011 | Rheem Water Heaters
Leaking from inside the tank this is a rheem GN-100-200
You posted under gas water heaters.
If water heater tank is leaking, it will need to be replaced.
If you have electric water heater, check if water is leaking around element.
Open following link for a troubleshoot checklist:
http://waterheatertimer.org/Water-heater-is-leaking.html
Also it is important to protect yourself from ruptured tank:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 23, 2011 | Rheem Tank Water Heater G100-200, 100...
Is my water heater still under warranty leaking water on top of heater and out from bottom and from plate
1) If water heater is leaking, I suggest you protect yourself first.
2) You have to do some work to find out if tank is under warranty.
-Contact manufacturer: http://waterheatertimer.org/Water-heater-manufacturers.html
-Contact installer: If plumber installed heater, then installer backs warranty for some manufacturers. If you installed heater, then warranty is less or void
-Look at paperwork and manual that came with water heater and read about warranty coverage
-Look at markings on tank to see if tank is 6 year, 15 year etc
-Warranty is based on date of manufacture: To find date of water heater, look at serial number located on label on side of tank:
Open link below for serial number decoder by manufacturer.
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
3) If tank is older than 6 years, and tank label shows this is a 6-year tank, then tank is no longer under warranty.
If you have a lifetime tank, then warranty is in effect, so contact manufacturer.
Open following link to see troubleshoot checklist for leaking water heater:
Other things to consider:
-If tank rusted out after a few years and installer did not install a jumper wire between hot and cold pipes, then tank warranty will probably not cover tank.
-If tank rusted out and you have water softener, and did not inspect anode rod or maintain water heater, then you did not read manual or maintain heater, and warranty might not cover problem.
-I suggest you read water heater manual cover to cover so water heater will not start leaking.
Other useful links:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Feb 12, 2011 | Reliance Water Heaters
Leeking water from bottom
I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Also run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
Nov 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
http://waterheatertimer.org/Water-heater-leaking.html
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
Nov 08, 2010 | RELIANCE ELECTRIC WATER HEATER
Water leaking in basement because there is a small leak in current expansion tank. can we stop water from leaking tonight and still have water to house? and are these tanks easy to replace?
For tonight I would set a bucket under it to cathc the water from the leak. The tank will not start to leak much worse in the next few hours...
And, no it is not hard to change the tank. Just messy....:-) Becareful though as the tank may be heavy if the bladder has ruptured...
Simply use two wrenches and unscrew the tank and then tape or dope the threads and screw the new tank back on...just that simple...make sure you get a fresh water exspansion tank and not a heating one...
heatman101
Mar 30, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
InSinkErator Instant Hot Water Faucet leaking from heater unit model #GN1100
Make sure that there is no leaks traveling down the hoses or at the connections on the top. The tanks can leak, if you have the Stainless Steel tank the following information applies - Stainless Steel Tank: 3 years, with an extended service plan available when installed by an InSinkErator Pro Circle™ plumber. I you product is under warranty I believe that you can call the number that is printed on the tank and literature.
Dec 04, 2008 | Mountain Plumbing Mountain The "Little...
Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641 Logo
271 people viewed this question
Top Mountain Plumbing Water Heaters Experts
rpar
paulcarew
Gene Haynes
Are you a Mountain Plumbing Water Heater Expert? Answer questions, earn points and help others
