Question about Ricoh Aficio SP C222SF All-In-One Laser Printer
I own a SP C222SF, and there is a malfunction. It says Service Call - SC400 and i have no idea what to do..please help
  • 95 Answers
SOURCE: Service Call Message
SC 400 is a dirty toner mark sensor. Clean with alcohol, wiping with dry cloth causes static on sensor and attracts toner. Not sure where the sensor is, but look around transfer belt unit.
Posted on Apr 15, 2009
  • 903 Answers
SOURCE: RICOH SP C222SF SC300ERROR WHAT IS IT. CAN IT BE
SC300 on a C222SF is a high voltage power error. You could reseating the connectors for the high voltage power supply and the engine board (EGB), but more than likely one of those two boards will need to be replaced.
Posted on Jun 03, 2010
  • 126 Answers
SOURCE: ON THE NRG SP C222SF
ok mate. i am a Ricoh technician. the waste toner bottle is located above the paper tray.take the paper tray out, then you will see a bottle inside on top of tray. it is flat and you have to pull it out and empty the waste toner from it. if you have any problems email me on ronils_singh@yahoo.com.au i will email you the diagram from service manual and the procedure.
Posted on Oct 01, 2010
SOURCE: SP C222SF multifunction Printer Problem
Dear colleagues,
I have aficio spc 232, when powering on, it stays displaying initialization message and never comes redy.
Please any one can help me to solve this problem.
Many thanks in advance
Boualem
UAE
Posted on Oct 05, 2010
  • 14 Answers
SOURCE: hello. i have Printer Ricoh SP C222SF indicated error code (service code sc400) any idea please
Your machine places marks on the brown shiny belt inside, to judge print quality. It reads these marks to see how dense the toner is. There is a bulletin stating that the "mark reader" sensor is possibly dirty due to a static or electrical charge drawing toner to it. There instructions on dis assembly for this on Ricoh's tech website, and I can't get there from this computer. But the main thing is to clean them with alcohol, not a dry cloth that produces static.
Posted on Jan 30, 2015
Hello. i have Printer Ricoh SP C222SF indicated error code (service code sc400) any idea please
Call Ricoh support, they'll tell you what it is for free and try to sell you service to fix it. 1-800-227-4264 in the US.
Jan 28, 2015 | Ricoh Office Equipment & Supplies
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
May 25, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Ricoh SP c222sf is not recognizing that there is paper in Tray 1 or bypass - tried to rest tray 1 and turn on/off, but the display still shows that there is no paper. What else can I try?
There is a paper detect sensor which sits in the frame of the machine above the paper tray. Pull the paper tray out and make sure this sensor didn't get broken or knocked out of place. (If you have a can of compressed air, shoot some into the sensor to get rid of possible paper dust.)
Mar 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Sc300 service call
On the SP C222SF, sc300 is a high voltage output error. More than likely, either the high voltage supply board (HVSB) or engine board (EGB) is bad and needs to be replaced. However, before going that far, you can try turning off and unplugging the machine and reseating the connectors that go to those two boards. Sometimes a loose connector can cause a service code, and fixing the connection can clear the problem up.
Feb 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
With colour output from a Ricoh SP C222SF Aficio I'm getting lines through all colours, from print and photocopy. Do I need to replace toner, or clean something...? Suggestions welcome!
Pull out your toner assys and look at the drums on each the should look clean under this is the belt that transfers all the colors it also should be clean, the last possibility is the fuser these are all maint items. Have you tried to check the maint items? (menu OK machine settings OK Supply info) or Menu OK machine settings OK TB clean.
-Carl, please let me know if this helps.
Jun 14, 2009 | Ricoh Aficio SP C222SF All-In-One Laser...
Dear colleagues,
Boualem
UAE
May 08, 2009 | Ricoh Aficio SP C222SF All-In-One Laser...
Ricoh Aficio SP C222SF All-In-One Laser Printer Logo
590 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
