Question about Whirlpool Duet GHW9150P Front Load Washer
Water filling in machine when idle. How do I fix this
  • 347 Answers
You have a solenoid hanging up in the fill valve assembly allowing water to enter in to the tub. The fill valve is the assembly that the hoses attach to ,it is easily replaced by removing the top of the washer to gain access...
Posted on Oct 09, 2010
Washing machine fills with water while sitting idle.
Another problem could be the inlet solenoid is failing to close properly, this could be caused by either an obstruction in the sealing part of the solenoid valve, a damaged or worn out seal or if the water pressure is too low. (some solenoids require water pressure to close off properly). To test this idea turn off the taps when not in use. If the water is still filling the tub, the back flow / syphoning idea may be valid. Also just to rule the idea out, turn off the tap to the machine and remove the inlet hose, if the tap "drips" this "trickle" of water maybe the culprit. If turning off the inlet tap fixes the problem you may need to replace the inlet solenoid.
Jan 08, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Cold water will not fill
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 27, 2011 | Maytag Washing Machines
Not filling with water
heatman101
Apr 18, 2011 | Whirlpool Washing Machines
Wont fill with water
heatman101
Feb 23, 2011 | Washing Machines
Will not fill with water
heatman101
Jan 29, 2011 | Maytag Washing Machines
IE water inlet error How do I fix?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 08, 2010 | LG WM-2277HW Front Load Washer
COLD WATER WILL NOT FILL; NO COLD WATER RINSE. MODEL NUMBER 110 26452502
heatman101
Sep 08, 2010 | Kenmore Washing Machines
The water is on but the water doesnt fill the washer. the spin cycle works how do i get the water to fill the washer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 03, 2010 | Maytag MAV8557 Top Load Washer
WHirlpool Duet Washer
Swede, you need to replace the water inlet valve. Part number 8181694. This is an easy fix. Just remove the 3 screws that are in back holding the top on. Slide the top back and you will see the valve. Couple of screws and a clamp and it will come right off. Catriver..post back.
Jan 19, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
