Question about Frigidaire 14 Cycle Tumble Action Washer
Error code e20 displayed on my washer?????
Can you help?? error code e 20 displays???
After several minutes of beginning a wash cycle, the washer will begin to make a beeping sound and a code E10 will appear. I press start again & it will continue the washing cycle.
However, it will do this through out the washing cycle. During a normal was cycle, I may have to press start again anywhere from 5 - 10 times.
Could you tell me what this problem may be?
Posted on Jan 24, 2009
  • 3 Answers
Can u help? Have same problem
Posted on Jul 28, 2008
What do I need to do when my front loader is giving me E20 code
Hey Kim, thank you for your post!
From what you have described your Frigidaire washer is displaying an error code of E20. I am not showing that as a valid error code and I would recommend performing a reset on your washer. You can reset your washer by disconnecting power from it for at least ten minutes. If you continue to experience issues with that error code please respond back and additionally provide me with your model number. You can locate your serial tag (which lists your model number) on the door frame of the washer. Once I have that information I would be able to further assist you. I look forward to helping you further. -Matt
Dec 12, 2015 | Frigidaire Washing Machines
How do you fix e20 code
Hello John, thanks for your inquiry!
From my understanding your Frigidaire front load washer is displaying an error code of "E20" and you would like to know how to fix it. An "E20" code stands for water is not pumping out fast enough this could be a problem with your drain hose, pump, or control panel. I would suggest checking the drain line to make sure it is not restricted. If the line looks clear it could be a problem with your drain pump or control panel. I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Apr 23, 2015 | Frigidaire GLTF2940ES Front Load Washer
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
My washing machine keeps giving me a error 20 code and dosent finish the cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
E 20 ERROR ZANUSSI JET SYSTEM
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Sep 07, 2009 | Zanussi FJS1225W Front Load Washer
E20 flashing mid cycle
Jul 01, 2009 | Zanussi ZWF1430W Front Load Washer
Atf7000ep code e20
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 code. Not draining
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Frigidaire 14 Cycle Tumble Action Washer Logo
498 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
