Question about Vacuums
How to thread IGIA Stitch & Go mini sewing machine.
e-Guru
  • 3917 Answers
SOURCE: while using the pin stitch
Please go through the link given bellow to have the resolution to your problem...
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 27, 2010
  • 5603 Answers
SOURCE: Janome sewing machine Harmony 2139 The
A common problem is if needle is in backwards. The small groove side should be toward the operator. As the needle starts back up after going clear down, a small loop should form on the side of the needle away from teh operator. The shuttle has a point that goes through this loop to snag the upper thread and carry it over the top of the bobbin. Also verify that needle is propely seated.
If an accident has happened with the machine that MIGHT have disturbed the timing, then that could be the cause and one would have to take it for repair.
Slowly watch for the loop, with covers off, and manually cycle to watch for the operation I have described.
Posted on Dec 03, 2010
  • 2069 Answers
SOURCE: I have a Yamata GC
well i would advice, that in this manual, you check on the adjusting thread take up stroke on page 19.
hope that helps
Posted on Feb 01, 2011
HansPP
  • 2510 Answers
SOURCE: I have an old kenmore
Check the tension on the bobbin thread and ensure that the bobbin is in the right way, the thread must double back on itself.
Posted on Feb 14, 2011
SOURCE: received stitch'n time sewing machine
If you email me I will scan the manual, and email it to you.
quintas3@hotmail.com
Posted on Jul 12, 2011
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
I cannot get the thread up from the bobbin from the Mini Multi-purpose crafting & mending sewiing machine
Hi. Are you sure that there is a long enough tail trailing from the bobbin? Are you holding the end of the needle thread while the machine rotates through the stitch then pulling it up after one revolution of the machine? If this is a tiny hand held machine, don't expect the same performance you would get with a full size unit, and it may take some figuring out as to what will make it work.
Sep 09, 2011 | Singer Vacuums
Thread gets under needle while sewing. needle then cuts thread. is this a bobbin tension problem? thanks!
Hi. My guess would be no. Sounds more like an upper or needle thread tension problem than a lower or bobbin thread tension problem. Your trouble could also be the thread take-up lever was missed when threading the machine. Trace the thread path to make sure the threading is correct. Is this an embroidery machine? If not, were you trying make a darning stitch? Perhaps with the foot raised? Keep in mind that raising the foot loosens the upper thread tension.
Sep 09, 2011 | Vacuums
I have just switched my singer 7463 on and all the lights on the stitch selection are flashing and it won't sew.
Most probably a threading issue. Turn off machine and be sure top transparent path is threaded correctly. Turn machine back on.
May 23, 2011 | Vacuums
HAVING A PROBLEM WITH MACHINE JAMMING UP AROUND BOBBIN AREA WHEN TRYING TO FREEHAND EMBROIDER IT STARTS OFF OK THEN QUICKLY JAMS UP HAVE ADJUSTED THE FOOTPLATE SO THERE ARE NO TEETH
Check your tension first by sewing a wide zig zag stitch. Does the top of the stitch and the bottom look identical? The sides of the stitch should look like a hole where the thread disappears to the other side, with no extra thread from the other side coming through. It also should lie flat and not be puckering in the middle. When it looks identical and no puckering the tension is correct. Use the same type of material and thread you will be using for the embordery. The bottom side of the stitch is effected by the TOP tension. The top side of the stitch by the BOTTOM tension.
Are you stretching the material you're hand embordering with a hoop?
The dog feed needs to be totally down and if your machine has an adjustment the tension on the foot should be lessened too. (not all machines allow for that adjustment).
Last but not least make sure you have the right needle for the job and material.
Jamming up in the bobbin area would most likely be from the top tension being too loose but also make sure the material isn't getting pulled down in by stretching it with an embordery hoop. Do use a presser foot... a wide clear one is best.
Apr 26, 2011 | Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
While using the pin stitch , the machine has started skipping stitches, knocking loudly, the top thread is breaking, sometimes thread knots up on the underneath side. I have cleaned bobbin area, changed...
Apr 27, 2010 | Vacuums
Vacuums Logo
606 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
