I have an 52 inch RCA in projection T.V. and one day it quit turning on. If you use either the remote or button on the front of set the green light turns on for a second then goes off. I you try to turn it back on the green light wont come back on for a few minutes.
  • 8,617 Answers
CP150, CP120 and CP114 capacitors will usually cause that symptom. The RCA repair kit by that same name is available at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions
Posted on Oct 09, 2010
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" REAR PROJECTION P52937 FRONT BUTTONS WILL NOT WORK
It just plugs in and try cleaning contact switches first with contact cleaner see if this fixes it.
Dec 19, 2008 | RCA P52937 52" Rear Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
Tv stopped working
Good Day, pjljr2000;
Sounds like you have a dead set. First try rebooting TV by unplugging for 5-6 minutes, make a/c outlet has power.
There are too many things on your model that could be the problem. If what I suggested didn't help and if you are not electronically inclined then I would recommend that you contact a factory authorized dealer to service the TV.
Good Luck, big IRISH.
Jul 04, 2008 | RCA P52926 52" Rear Projection Television
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch TV (turn on problems and channels rolling) HELP!
Your set uses the 195 series chasis. The only thing I can think of which would make the channels scroll by themselves is a contaminated PC board and pushbuttons behind the buttons on the front of the set. This is usually the case when spray cleaner or some other fluid is sprayed or spilled on the screen, and it drips down onto that board. To prove this, remove the back cover and on the top of the main chassis, where the top of the picture tubes are, is a small PC board with the remote reciever and a couple of jacks. The smaller jack is for the speakers and the larger jack is for the front panel PC board. Unplug the larger connector which goes up to the front PC board and then turn the set on with the remote. If the set works normally, the front PC board will have to be removed and cleaned or repaired (or just leave the jack unplugged and work the TV from the remote only). If you do not have any experience working inside projection sets then allow a qualified tech to handle it for you.
Aug 30, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
