Question about HP G60-235DX Notebook
Where is microphone located for use with Skype on HP G60-235 Notebook PC
SOURCE: Keyboard and touch pad will not work
The HP50 and HP60 laptops both have a lock button I just discovered by tripping over it today. Couldn't find a description of it in the printed or onboard manuals. This button is in addition to the overall computer lock function key (f6) that is well described. This keyboard/touchpad (k/t) lock button is obvious when pointed out, but less so when those items are already locked out by casual hand motion. The button is located just above the touchpad and is embedded in the border trim of the keypad. It toggles access to your k/t. It has a little indicator light so one doesn't miss it, but it is pretty low-key, if you forgive the pun. Designers can be a little too cool sometimes!
Posted on Nov 12, 2009
  • 16 Answers
SOURCE: hp pavilion dv1000 entertainment notebook PC - my
You can try the following link to get original drivers from HP.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432999
You may also try to uninstall through Device Manager and allow the PC to rediscover the mic again.
Posted on Nov 02, 2009
  • 18 Answers
SOURCE: reset bios jumper motherboards for HP G60-519WM
If this is really an HP G60, the fix is really not that difficult.
Shut the system down, remove the main battery and the AC power cable from the laptop.
Remove the Hard Disk Drive cover from the bottom of the laptop (2 screws).
Next to the Hard disk you will see the CMOS battery --- it is about the size of a penny and covered in dark tape. Two wires lead from this CMOS battery to a plug about 1.5 inches away. Disconnect this plug, wait 5 minutes, and put everything back the way it was.
Restart the system ---all CMOS settings and BIOS passphrases will have been reset.
Posted on Apr 20, 2010
Srikanth Kos
  • 69 Answers
SOURCE: HP G60-120US 15.6" Widescreen Laptop PC Notebook: when trying to turn the computer on, the 3 lights ...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
Posted on May 19, 2010
Microphone
Sorry but only the latest models have a built-in microphone. I've even searched the tech manual for you without success. You;ll have to buy an external mike and plug it into the microphone jack.
May 04, 2012 | HEWLETT-PACKARD HP Pavilion Dm42070us...
I have a Pavilion dv6-3025dx and cannot get the sound to work for skype. Obviously there is a camera and that works fine but I could not get the audio to work - do I have to add a microphone. Can you help?
I understand that you are not able to us the microphone with Skype. As per the information provided in User Guide for the model it seems that the model has an Internal microphones .
Try configuring the internet microphone to use with Skype.
Open Skype - Tools - options- Audio settings- Set the input device as internal microphone and check the operation.
Aug 22, 2011 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
I have hp pavilion dv1000 computer. i was using skype v3 for two years with no problem. then i installed skype v5.3. Since then my microphone doesn't work. It looks like some setting got changed. I...
I think you are right.
Try changing your audio-settings, until your mic works again.
I've you still need help, i can remotely control your computer to fix this problem
Good luck,
DJ Skywalker
Jun 19, 2011 | HP Pavilion dv1000 Notebook
When I use my headphones for skype of my Pavilion dv7, the microphone dosn't work. Why???
Assuming that the microphone jack is correctly connected, go to sound properties in Control Panel and check that microphone is checked and that the volume is correctly adjusted.
Hope this helps
May 09, 2011 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How do I connect microphone/loudspeaker for Skype connection?
1. Plug it in, unless it's built into your Notebook. 2. Update the Drivers on your Microphone. You can also reinstall the drivers of your Sound Card if you want to be picky :P
3. In Skype, go to Tools > Options > Audio Settings and click on the drop down box next to Microphone. Change that to the Microphone you want to use and select Save. You should be good to go.
May 03, 2011 | HP ProBook 6440b Notebook
Can you pls let me know how do I fix my laptop microphone (HP Pavillion dv1000); when using skype others cannot hear me (or when I do the test on skype, I cannot hear my own message). I have checked the...
Assuming you are using Windows 7
<Start>, <Cotrol Panel>, <Ease of Access>, <Speech Recognition>, <Set up Microphone> Follow prompts and instructions. Once your Microphone is set up, your Skype will work.
Mar 20, 2011 | HP Pavilion dv1000 Notebook
My webcam does not function anymore when i use my skype i dont have an image
Please check if the webcam is detected in the device manager, if yes then follow the step's below. Skype To set up and use your webcam in Skype, follow the steps below. Be sure to upgrade to the latest version of Skype from http://www.skype.com .
  1. Log into Skype.
  2. Double-click a user also logged into Skype from your Contact List to begin an instant message.
  3. Click the Check settings icon to set up your microphone, speakers, and webcam.
  4. NOTE: Sometimes, Skype does not recognize the HP default microphone. If the microphone is not working, go to Device Manager and select the Integrated Microphone Array .
  5. Click the Video Call icon to begin a video chat.
  7. An invitation will be sent to the other user. To start the webcam, the other user must click Answer . A video image will display in the instant message.
  8. If the other user wishes to share their webcam with you, they will need to click their Video call icon, and you will need to accept their invitation when prompted.
  9. To end the video chat, click the red telephone icon c02035254.jpg .
Jun 13, 2010 | HP Hewlett Packard Pavilion dv6626us PC...
V6105NR MICROPHONES DO NOT TRANSMIT
Does your microphone work with other applications.  If you are running windows XP, go to Start>all programs>accessories>entertainment>sound recorder.  Record your self and play it back.  If you can hear yourself, then the issue is with skype.  Make sure you go through the audio setup wizard in skype to get the best preformace out of your microphone.  If no other programs work, then you may need to reinstall the drivers for that microphone and try it again.
Mar 04, 2009 | HP Compaq Presario V6105NR Notebook
Microphone
i think you would need a seperate mic for that laptop.
Feb 25, 2009 | HP Pavilion ze2000 Notebook
Skype cant hear me
yes sir,you need to have a microphone, i believe there is a microphone port on you computer..
Jun 24, 2008 | HP Compaq Presario V2000 Notebook
HP G60-235DX Notebook Logo
168 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
