No connection to the internet on the secondfloor of our house.connection on the ground and first floor
  • 340 Answers
Make sure all is plugged in correctly. Then go to your modem and reset it, just unplug the power to the modem for about 10 seconds and retry, if you have wireless, do the same to the wireless router, unplug and try again. If this still does not work you may need to refresh your ip address. To do this go to the computer that is not working and type in the following... go to start and in the search box type cmd. a black box will come up with C:....... type in there ipconfig /release it will go thru a series of lines then give you the C: again next type this... ipconfig /release this will renew your ip address and hopefully allow you to connect once again. Let me know if this works or not. If not we'll try something else
Posted on Oct 09, 2010
Connection loss
Watch what else is going on in the house when the connection is lost. Microwave ovens and cordless phones will disrupt the connection . How far is the router from the TV? You might try elevating the router if it's neat the floor. The higher off the ground the router is the farther the signals will go. Yo may need to upgrade the speed of your service if it isn't the highest speed available.
Jan 03, 2014 | JVC 55 1080p Smart Wi-Fi 3D 120Hz LED HDTV...
Laptop running windows vista won't connect to router in Europe.
You need to call the internet provider. They more than likely have a different protocol to set up in order for your internet to work.
Jun 25, 2012 | HP Computers & Internet
Every time I try to connect to the internet it my DS keeps 'No compatible access point in range. Check your connection settings and try again. For help visit suppoert.nintendo.com Error code:...
You can only connect to internet if someone is sharing their Wifi. If it is password protected, you won't have any luck. You're best off heading to Starbucks or McDonalds for free Wifi to connect to the internet.
Jun 18, 2011 | Nintendo DS Lite Console
How do i ground my antenna base or mobile ?
If you're using it in a car the antenna makes contact with the body of the car either through the magnetic base, if you're using one, or the metal clip if that's how you attached the antenna to the car. Either way the contact between the antenna and the body of the car acts as a ground.
If you're using it in your house it depends on the type of antenna you're using. Home base antennas have spikes that stick out from the base of the antenna. These act as a ground. If you're using a mobile antenna in your house, which will not give you a great signal, you need to connect it to something metal. Linking the body of the transceiver to the copper piping of your central heating or water heating system provides a good ground for the radio. As the ground of the antenna is connected to the metal of the transceiver body this is the same as grounding the antenna. Even if you're using a proper homebase antenna it's still a good idea to earth the radio as it improves the signal and reduces noise interference
If you're using the CB on a ground floor you may be able to run an earth braid wire outside and put a metal spike in the ground and connect it with your earth braid. Connect the other end of the earth braid to the metal on the body of your radio. NOTE: When connecting an earth to the body of your radio it must not be a painted part of the radio. You could drill a small hole in the body if necessary and put a nut and bolt through it to connect to the earth wire.
I hope this answers your question.
Jan 08, 2011 | Cobra 19 DX IV CB Radio
I have an old Victorian house with an apartment in the back above the barn/garage. I am trying to get wireless internet connections to all sections of the house but my current router (3 years old) is not...
Hello.
Yes. As you mentioned, you have a Victorian house, with very thick walls. I'd suggest drawing a diagram showing the rooms and floors that need access.
First, if possible, I would place your router in a centralized location, if all 5 people need similar strength access.
Then what you need are multiple repeaters to go with your router. Place them strategically, so that the wireless access signal can bounce off of them and go around walls, instead of through walls and floors.
Hope this helps.
Nov 22, 2010 | Computers & Internet
Please provide me HCL service center number at bangalore ? sandeep065@gmail.com
>web nirnaya, G11, Lucky Paradise building, Opp.Kuch Bhi, Jayanagar 3rd block, bangalore - 095 35219501 >ground floor , Lucky Paradise building, next to Sri Balaji Drug House., 22nd cross, 8 f main road, Opp. ICICI Bank, Jayanagar 3rd Block, bangalore - 092 42949502
>#11, Ground Floor, Lucky Paradise Complex, 22nd Cross, 8th F Main Road,, Opp. ICICI Bank, Jayanagar 3rd Block,, bangalore - 090 36211701
Aug 16, 2010 | Computers & Internet
Can I setup a cable modem with a router
You can if the router is wireless and you have a wireless card in your computers. If not, then you will have to upgrade the router to a wireless and get wireless cards in the computers or run a cable to the 2nd floor
Oct 26, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Wii USB Adaptor
the easiest thing to do is to get an usb wireless adapter for about 30 bucks , connect it to your pc or laptop , set it as an access point , then just use the built in wifi on the wii , to get on the net, hopes this works , did for me
Oct 30, 2008 | Computers & Internet
Self-assigned IP address and may not be able to connect to the Internet
if its a wireless network it assigns yyou an ip immediately solong as you are not connecting directly so dont bother about the ip just connect and see what happens.
Oct 27, 2008 | Lucent ORiNOCO AP-500 (8485878380)
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
