Question about Logitech Z-5500 Computer Speakers
There is no sound coming from my z-5500 system, even when trying the test function there is no sound. Please advise on what the issue is.
  • johnsav654 Oct 09, 2010
    Thank you for your help I will give them a call
    President:
  • 2,777 Answers
That indicates the amp built into the subwoofer has failed. This is definitely very bad news indeed. You are going to want to contact Logitech to see about a repair of the unit. I have seen a handful of these things go bad, it's an extremely difficult repair and needs to be done by the factory. Please give them a call at 646-454-3200
Posted on Oct 09, 2010
Sony MHC-GS200 does not play CD's and emits a squealing sound when unit is powered on. Sound comes from CD compartment even when Radio is selected. Carousel will not rotate either.
The only way to find out will be to open it to view the CD area. Then power it up. And watch what happens.
It could be a foreign object in the mechanism.
Nov 30, 2016 | Sony MHC-GS200 CD Shelf System
Why have 3 out of 5 speakers on my PC stopped producing sound even after configuring and updating drivers??
Sounds like a configuration problem. See this... http://www.logitech.com/en-us/support/224
Also, visit Control Panel/Sound, select your Default Device, and click "Configure" to verify that the configuration is set correctly.
Jul 15, 2014 | Logitech Z-5500 Speaker System Control...
I can't use the built-in web cam,i'm using a skype but i could'nt use the video call coz the web cam is not functioning? help me pls tanx
Sounds like a driver issue try this and install it:
http://www.driversforfree.com/Drivers/a9c3fadb-2e08-4023-a368-87828a9a03b9.aspx
This link is for one of the many different types of webcam Acer put into their machines if it doesn't work goto this link and try a different one:
http://www.driversforfree.com/omn_ofm_omd_dt/acer/aspire/5500/webcam/drivers.aspx
Hope this helps
Mar 20, 2011 | Acer Aspire 5500 5570-2609 Laptop
Sound Quit
Replace the logic supply board inside by finding someone on ebay with just the controller or take it to a repair shop is the only 2 solutions at this time for you, thanks and good luck..
May 15, 2009 | Logitech Z-5500 Computer Speakers
Nvidia GeForce FX 5500 / 256MB... Problem
Hi jhacy, I went over all you're posted questions conserning this issue with the FX5500 video card. Please include the manufacture name of you're motherboard & its model number. It is possible the video card is bad (Even if it's new). There are settings in the motherboard bios that me need to be shut off if the motherboard has an integreated video card onboard. It's possible that the AGP slot on you're board is dirty & needs to be cleaned. Please list the name or name's of the games you have tried to run but freeze you're computer or crash you're system.
I will automatically recieve an email from fixya when you post the information I have asked for above. Untill than, take care!
Jun 01, 2008 | Nvidia GeForce FX 5500 Video Card Graphic...
No sound coming out of z-5500
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 24, 2008 | Logitech Z-5500 Computer Speakers
No sound from speakers at all
Manual
Cheers!
IrishDruid
Sound from 4 speakers cut off..
Manual
Cheers!
IrishDruid
May 20, 2008 | Logitech Z-5500 Computer Speakers
No sound
Have you checked if this is only when you play CDs or also if you play Tapes or Radio? If sound is not present even if you use radio and tape, then the sound output IC is blown, and needs replacement. You need to see a professional technician for this. Also, see if your speakers are connected properly. Then try to connect another set of speakers (borow from a friend) and see if sound is audible. If yes, thn your speakers are faulty.
Aug 09, 2006 | Crosley CR79 CD Shelf System
Logitech Z-5500 Computer Speakers Logo
618 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
