Question about Master Heaters TA107
I have a desa gas wall heater GWRN18. My burner assembly has a bad brick or watever you call is on the right segment.. It has fire flaming out of the segment.
Pilot light goes out when you turn it down to just one burner
From what you described, it may be a case of turning the control knob down to far and it's turning the pilot light OFF.
Other causes:
1. Unit needs cleaning and servicing due to a dust and lint build up inside the heater.
2. ODS Pilot Sensor is partially clogged.
3. Low gas pressure.
4. Thermocouple is failing and needs to be replaced.
In case you have misplaced the Owners Manual for this model heater, I have included a link to it. You can download and print the manual for future reference.
http://www.desatech.com/manuals/Vent-Free%20Heaters/107885-01.pdf
In addition, I you want to undertake the cleaning and servicing process, I have also included a link to a "How to Clean the Pilot Assembly" demonstration.
http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
You model heater uses the Copreci Pilot Assembly.
Armed with all this information, you should be able to further troubleshoot and solve the problem.
Hope this helps you. Please let me know. Thanks!
Apr 14, 2011 | Desa International GWRN18 Infra-Red Wall...
The flame is orange and I noticed it was running high and when we leave it on one burner it wants to shut off. I have dusted and cleaned it and it didn't improve it. Now when we go to light it usually...
Sounds like thermocouple is part of the problem as it relates to lighting the heater. Overtime, they do become pitted or corroded and should be replaced. As far as the orange flame when running on high is concerned, it sounds like the air intake valve on the burner is partially clogged with dust or lint. I realize you said, "I have dusted and cleaned it and it didn't improve it" But, if you didn't take the front of the heater cabinet off and cleaned all if the interior (including the burners, the plaques, the pilot and the interior walls of the cabinet), your cleaning wasn't sufficient. A Shop Vac with a hose, brush attachment and crevice tool works real well to help you accomplish this. Also, a can of compressed air with a straw nozzle (like you clean your computer with) will aid you in cleaning the pilot orifice and the Oxygen Depletion Sensor (ODS). To further assist you, I have included a link to your Owners Manual (in case you have misplaced yours) that you can download and print for future reference.Be sure the heater is cool and the gas has been turned off to the heater, before attempting to clean the heater.
Hope this helps you to solve the problem.
Mar 19, 2011 | Desa International GWRN18 Infra-Red Wall...
I bought a new Desa heater that still had the tags on it from a private owner, never got it hooked up. It is the infrared gas heater GWRP16, GWRN18, manual I have to go with it. It did not come with a...
Yes, click on the following link and it will take you to Master Distributors. They stock DESA/Vanguard parts. Sorry that you'll have to pay for something that was supposed to come standard with the heater. http://www.vanguardheaters.com/
Be sure you have your Model Number handy when ordering.
Mar 09, 2011 | Desa International GWRP16 16,000BTU LP Gas...
Control knob gets too warm and starts to melt/losen from shaft.
I don't know how old your heater is, but from what you have described, sounds like a run-a-way burner. In other words, the burner has failed and is producing to high a flame height. Thus, overheating the metal cabinet and causing the control knob shaft and knob to become extremely hot.
Although this heater has a stainless steel tube type burner, It is not beyond the possibility that the burner has rusted out somewhere along the burner tube and flames are shooting out in the wrong place(s). This could be especially true, if the heater was not cleaned and serviced on at least an annual basis.
The only way to check this out is by dismantling the heater cabinet, to expose all of the internal workings. It is not difficult to os, just be sure to turn the gas line to heater OFF and let it cool.
Remove the sheet metal screws along the outer 4 sides of the heater and the cabinet's front can be removed. Check the burner and it's gas connections carefully, to find any degradation that may have occurred, as well as any char marks inside the cabinet.
I have provided a link to your heater's Owners Manual, which should be of more help. You can download and print it if your so desire.
Until this problem is solved, it would be in your best interest to stop using the heater all together.
Hope this helps you find the problem and solve it.
Feb 27, 2011 | Desa International GWRN18 Infra-Red Wall...
The center ceramic segment does not glow red like the outside ones, it stays more blue, is there a flame adjustment?
No, no flame adjustment, but that section of the burner, behind the plaque may be clogged. If you don't service your heater at least annually or have it serviced annually, more than likely that's the problem. Also, check the condition of the plaque in question. Depending on the age of the heater, it may simply be cracked or worn out.
If you discover it needs replacement you can order one from FMI (the company that bought part of DESA International after the bankrupted) by calling 868-328-6951, then press 2.. You will need to have the Model # & Serial # of your heater when you call.
Feb 09, 2011 | Desa International Blower Glow Warm Wall...
Yellow gas . cleaned burner which is made by Worgas. Still yellow tipped
yellow flame is caused by low o2. so open air shutter or lower gas input. that said if flame is equal across burner.a normal gas pressure to the burner is 3.5 " w.c. there should be a test port on outlet side of valve. the name plate will tell you what the pressure should be.
Jan 04, 2011 | Desa International GWP20T GLOWARM Wall...
Flame on infrared wall heater ceramic burners burns blue on the surface and the burners no longer turn red or only partially turn red. I have taken the gas lines loose from the bottom of the burners and...
Check the gas line pressure before the heater then after the regulator. It sounds as if you are not getting sufficient gas pressure to the burners. Two possibilities bad regulator and or bad gas valve! Sorry I can not be absolutely sure on this one you can try blowing the ceramic burners with a compressor this will clean them rite out.
Dec 13, 2010 | Desa International GWP20T GLOWARM Wall...
CBN30T,DESA, pilot lights, but flames out when the burner comes on.. burner stays on a few seconds and shuts off due to cold thermo-couple. pilot flame seems to jump up and disconnect from the jet, as if...
ONLY ONE OR TWO THINGS AT FAULT.YOU HAVE A BAD THERMOCOUPLE.THIS IS PROBLEM 90% OF TIME AND CHEAPEST REPAIR.IF THIS DOES NOT SOLVE PROBLEM GAS VALVE IS BAD.HOW IT WORKS:THERMOCOUPLE WHEN HEATED WITH PILOT FLAME CREATES ASMAAL ELECRTRCAL SOURCE THAT HOLDS A MGNET OPEN AFTER HOLDING THE PILOT DOWN FOR ABOUT A MIN..THEN TURN GAS VALVE TO OPEN POSITION AND MAGNET WILL HOLD GAS VALVE OPEN.IF GAS VALVE DOES NOT STAY OPEN IT USUALLY INDICATES BAD GAS VALVE
Oct 13, 2009 | Desa International GWP30T Heater
Glo Warm propane heater started to go out. I blew out the pilot with air compressor. It is staying on, but the middle burner in back of the pilot light is flaming a little above the brick. The other...
sounds like when you blew heater out with air compressor you moved brick so flame isn't hitting bottom of brick like they should. You should try and put brick back on top of flame so that you don't get to much heat on the refractory of the heater.The refractory will take the heat for awhile then refractory will start to break down. Then you will either have to install new refractory or replace heater
Jan 17, 2009 | Desa International GWP20T GLOWARM Wall...
Master Heaters TA107 Logo
48 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
