Question about Philips 28PW6006 28" TV
Phillips TV wont stay on - Philips 28PW6006 28" TV
Phillips tv wont change channel
tried with pressing the channel button at the panel tv or using with the remote controller doesn't work?.
Oct 26, 2012 | Philips Phillips 2422-549-01929 Tv Remote
37in model 37pf7320a/37 , wont stay off settings mode
I fixed a Phillips 37" TV that was doing this by re-soldering the wire/pin joints on the button board (side of TV). You have to take the TV apart and have a soldering iron to do this, of course. But it's really not that hard to do.
I'm a caveman, and I did it!
Dec 05, 2009 | Televison & Video
16 in symphonic lcd tv wont stay on. Itcomes on for about 30 seconds then shuts off. But it will come back on by itself and do the same thing.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 27, 2009 | RCA F27450 27" TV
Wont stay on turns on for a second then i hear a
I have had the same problem with every Phillips with which I have had any experience. Service required, possible DOA.
Apr 17, 2009 | Philips Televison & Video
TV DOESN'T STAY ON BUT A FEW MINUTES THEN AUTOMATICALLY TURNS OFF
lost my code book need the code for a phillips universal remote for a konka tv.
Oct 19, 2008 | Philips Magnavox Learning Universal Remote
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Philps Universal cl034 needing codes
i need the tv code(toshiba tv) for my phillips universal remote control model CL034
Dec 28, 2007 | Philips RC2573 Remote Control
Philips 28PW6006 28" TV Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
