Question about Samsung SC-D103 Mini DV Digital Camcorder
I am trying to find a SD card that will work in my Samsung Digital-cam Model: SCD 103. A regular SD card will not fit in the slot on my camera. The manuel just calls for a SD card. I need more details.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
The SC-D103 doesn't take SD cards. It takes Sony Memory Sticks and compatibles from third-party manufacturers such as Lexar and Sandisk. Be careful, it will not take Memory Stick PROs.
Posted on Jun 10, 2011
When insert maxell maxdata 4 gb memory card camera says card read error
The A402 works with MMC and SD cards. Your 4GB card is an SDHC card. While it fits into the slot, it's electronically incompatible and won't work with the camera. You need to use an SD card, 2GB or smaller.
Mar 18, 2013 | Samsung Digimax A402 Digital Camera
Check sd card
The V800 works with SD cards. Your new 16GB card is a SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to go with SD cards, 2GB and smaller.
Feb 23, 2012 | Samsung Digimax V800 Digital Camera
How do i get an 8gb sd card to work in my vivitar dvr-530 cam corcoder?
The DVR-530 works with SD cards, which max out at 2GB. Your 8GB card is actually an SDHC, not an SD card. While SDHC cards fits into the slot, they are electronically incompatible and will not work in this camcorder. You need to use SD cards, 2GB and smaller.
Sorry if that wasn't the answer you wanted to see, but that's the way this camera works.
Sep 11, 2011 | Vivitar dvr-530 Digital Camera
What kind of Memory Card do I use in my Samsung Digital-Cam 103 I got 8GB, It will not fit in the Slot of the Camcorder
The user manual is here http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=04020100&prd_mdl_cd=&prd_mdl_name=SCD103
the 103 model is limited to the Sony Memory Stick - see page 82 of the user manual and can NOT use the Sony Memory Stick PRO or any other format of card.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 05, 2010 | Samsung SC-D103 Mini DV Digital Camcorder
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
The camera says xd and sd compatible but it seems that the card is getting stuck and wont fit into the slot for the card?? any ideas why? i just bought the camera 2 days ago
The camera has one xD slot, and is supplied with an adapter which fits into the slot if you wish to use micro-SD cards. Regular SD and mini-SD cards will not fit.
Jun 29, 2009 | Olympus FE-25 Digital Camera
NEED OWNERS MANUAL AND ACCESSORIES SAMSUNG SCD103
i have this vedio dvd cam this does not go to play mode.it always says eject c(model # SC-D6550
May 28, 2009 | Samsung Video Cameras
Memory card error
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Apr 14, 2009 | Samsung Digimax 401 Digital Camera
NO DISPLAY ON LCD IN CAMERA MODE
i have this same problem for a while and just stumbled on the (yet to be verified) solution. www.samsungclassaction.com. if this settlement is legitimate then Samsung will repair for free! (and refunds for people who paid Samsung to repair). the site asks for contact info but i worry about scams so i'm going to contact Samsung directly.
i hope this is real!
The affected models include:
SCD 23, SCD 27, SCD 103, SCD 107
Nov 07, 2008 | Samsung SC-D107 Mini DV Digital Camcorder
Shutter dosen't open, Black Screen while recording
there is a couple other posts on Fixya regarding this issue, the CCD sensor going bad and resulting in no image. i have the same issue and i just stumbled on the (yet to be verified) solution. www.samsungclassaction.com. if the settlement is legitimate then Samsung will repair for free! (and refunds for people who already paid Samsung for repairs). the site asks for contact info but i worry about scams so i'm going to contact Samsung directly.
Dec 31, 2007 | Samsung SC-D107 Mini DV Digital Camcorder
Samsung SC-D103 Mini DV Digital Camcorder Logo
191 people viewed this question
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
