Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Rowe jukebox The carousel spins when selection is made but the arm won't pick up the record.This is model # R-89 and serial #1039944. Any help to get this up and running again would greatly be appreciated. Thank you
    Scholar:
  • 195 Answers
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
CCC
Mechanism Control Board
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
Nothing moves when record selected
You're too far away for me so i would suggest getting another mech
Mar 27, 2014 | Audio Players & Recorders
Rock o la jukebox wont pick up record to play
I actually have the answer to your problem, there are 3 things, if you make a selection and it goes to it but wont grab it, that means the gripper motor is bad.
If your carousel keeps spinning I think its like the wurlitzers, your index light or orbital reader bulb is bad, 2 names but same bulb, depends on who your talking too,
and the last thing it might be is yes your safety switch, happens when someone grabs the arm it can be moved and then your dead in the water, the cd models also have an on & off swtich so check that too. Hope it helps
Feb 20, 2012 | Audio Players & Recorders
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Record tracking problem
There is a switch, or lever to a switch, that detects the end of the arm travel. For some reason, it is being tripped early. Try to open it up, and see what you can see. It doesn't sound like a broken part, but a dislodged part, maybe. That's all I remember, only had this problem once, years ago.
Mar 14, 2010 | Audio Players & Recorders
I have a 1979 rowe ami jukebox model R65 when i switch it on it plays one record then just spins the record magazine and wont select another record what parts do i need .
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
In the UK contact me
Alan Hood
ami-man
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
alan-hood@datex.co.uk
Mar 01, 2010 | Vintage Jukebox External Speakers Shelf...
Rock-ola 498 Carousel Spins Continuously
Look on Ebay for manuals or try at www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Sep 02, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
685 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
