Samsung LA37A550 After using headphones audio-jack with home sound system the TV's own speakers ceased functioning. Meaning that now, the only way the TV can be heard is through that headphones jack. When unplugged the sound does not get back to the speakers and remote control volume change appears as headphone volume level on screen not the built in speaker's volume (that is shown by appropriate image sign on the volume on-screen indicator). It is like TV got stuck with headphones ouput forgetting that it has its own speakers. What can be done to reset this setting in a TV? Thanks
SOURCE: Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Posted on Dec 26, 2008
  • 44 Answers
SOURCE: want a TV wireless headphone with no headphone jack or audio out
You may have to connect the headset through a VCR or DVD player that does have the output connections.
Posted on Sep 05, 2009
SOURCE: Need headphone solution for Panasonic c12lcd tv
I have a Panasonic viera 32in lcd hd tv. I'm trying to hook up headphones but there's is no apparent audio output jacks. But there's is only one digtal output jack! is this the jack ? and if it is, what cables do I need to make the headphones work? or am I forced into by an amplifier
Posted on Nov 22, 2009
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
  • 901 Answers
SOURCE: Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Posted on Jul 07, 2010
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
I have a samsung plasma 50" tv, how do I hook it up to this sound bar? I tried to hook it up using the rca jacks and it didn't work.
Near the Audio / Video inputs on your tv, you should see a "headphone" jack or it may be labeled "Audio Out"
some sound bars plug into these jacks using standard heaphone jack.
Other sound bars may need to be connected to the device your using on your tv. (DVD player, cable box, etc.)
Tv speakers can then be disabled in the "Audio" menu of your tv.
Dec 02, 2014 | Samsung Televison & Video
I have an older home stereo system that i would like to connect to my vizio tv. I have a 3.5mm audio to rca plug. Coming out of the headphone jack on the tv, it plays no sound out of the system. Although...
I suspect what you're wanting to do is take the audio output from the TV and run it through your stereo system to leverage the large speakers. Correct?
I suggest using the RCA audio jacks (red and white pair) on the back of the TV. Most TV's still have these. Some are tied to a specific component, and some are general for all sound coming out of the TV. You connect this to the input RCA jacks on your stereo system.
The headphone jack on the TV could also work, but I suspect it may have a low level output. I don't understand how you say your MP3 player plays fine through the headphone jack, as that's an output, not an input. Unless there's some other jack?
Sep 22, 2013 | Vizio 29in Class LED 720p TV - LED TVs
How do I turn off my 550 Samsung tv speakers?
Take the audio out from the audio output RC jacks (Red and White). Then connect a headphone into the headphone of the TV. The speakers then will then get off. Never insert a dummy stereo jack, as the amplifier without speakers can get damaged (depends on the audio IC used).
Jul 18, 2012 | Televison & Video
I have a Dynex Flat Pannel TV with a DVD player in the TV. I have it hooked up to my HD line coming into the house. My question is: Is there a way to hook speparate speakers from the TV and by-pas the...
Yes you can provided your tv-has a headphone jack. Just plug in any regular computer speakers or the like into the headphones jack and the audio output would be switched to external speakers automatically. On the contrary if your tv does not have a headphone jack then you will need to obtain a home-theatre system and connect the stereo audio out ports to the audio in of the home theatre system. They have become very affordable these days and I have seen a Philips home theatre system(2.1) starting at around 120$.
Apr 04, 2011 | Dynex Televison & Video
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
To play laptop thru samsung tv I am attempting to play laptop movie thru tv. I have tried the rca y cable with 3.5 mm plug from headphones of laptop to red and white audio in on the samsung tv., no sound....
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
How do i connect my headphones? when i use a red/white tulip - jack out cable and then connect the headphones jackplug there is no sound, using the 'variable sound out'. should i use an amplifier like a...
If your TV does not have headphone jack outlet, then there is not much you can do, the Audio line level out RED and WHTIE RCA jaks are not made to drive headphone directly, it does not have enough power to drive low impedance load such as headphone which has about 8~32 Ohms impedance, the line out RCA is made to drive high impedance load 20,000 Ohms and higher.
If you want to use headphone, what you can do is to get cheap powered PC speaker system that has headphone out jack, then just connect the powered PC speaker to the audio line out of the TV, but the TV must have an option on the audio setup to turn off the built-in speakers.
Jun 12, 2010 | LG 26LC2R 26 in. HD-Ready LCD Television
I hvae just purchased a Samsung HXT 30 sound system and connected it to the tv anbd sky hd box how do I get sound from the tv it would appear it is a problem what cables do I need I have aq HDMI from the...
You need to run a cable from your Sky (satellite box) box's 'Audio Out' jacks to the sound system's 'Audio in' jacks. Make sure the Sound system is set on the same function as where you plugged in the cables (RCA type, red & white) on the back of the sound system. (example: if you used the 'Auxilliary' jacks, set the sound system on 'Aux')
If it's sound 'from' the TV as well as the sound system you'll need to connect another set (of red & white RCA) cables from the Sound System's 'Audio Out' jacks to the Television's 'Audio In' jacks. This should give you sound from both the TV's speakers and the Sound System. Good Luck!
Nov 30, 2008 | Samsung HT-Q100 System
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
