Question about Compaq Presario SR1030NX (DW256A#ABA) PC Desktop
The computer will not power up. If I disconnect the HDD, everthing else seems to get power but as soon as I plug in the HDD, the power fails. I have to upplug the power cord and wait a while to get power back.
  • d_meadows679 Oct 09, 2010
    It is connected properly
  • Compaq Master
  • 5,660 Answers
Suggest you have a bad Power Supply, d_meadows679.
Weak voltage power rail.
Try another ATX power supply that is KNOWN to be good, and is compatible.
{Compatible:
Has the correct power cables.
Has the correct amount of power cables.
Is an ATX form factor power supply.
Case:
ATX form factor
Size and shape;
Approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall}
1) ALL the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power
3) A typical Processor uses 51 to 125 Watts of power.
[ Compaq Presario SR1030NX uses an AMD Athlon XP 3000 , in a Socket A processor socket,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Barton.22_.28Model_10.2C_130_nm.29
74.3 Watts (TDP)
http://www.cpu-world.com/CPUs/K7/AMD-Athlon XP 3000 - AXDA3000DKV4D.html
Now plug all these babies in together, (To include the HDD), and a power supply with a weak voltage rail, will fall to it's knees.
Posted on Oct 09, 2010
    Sergeant:
    Champion:
  • 214 Answers
Please make sure you are connecting the HDD Power connector properly.
Machine keeps putting msg HDD error has occured. Please disconnect the AC mains lead & reconnect it, then press POWER to restart. I have done this many, many times.It just keeps showing above msg.
take it to a computer repair shop for a diagnosis of the problem , but the message is specific
the hdd is failing
if that is the case replace it with a SSHD which has no moving parts or disc
Feb 03, 2017 | Power Computers & Internet
Gateway all in one touch screen went all black one long and two short beeps.what happened
Ok first turn the power off at the wall & disconnect the power cable, now open your computer. Once open if you do not have an ani-static strap simply touch the case to discharge any static and keep your hand there. Whilst you have one hand on the case with the other hand gently press down on the ram & any add-on cards to ensure they are seated fully, secondly again whilst still holding the case with 1 hand make sure that all other connectors such as power, hdd, etc & all connections to the motherboard are fully seated. Then after you have done all this plug you power cable back in and re-connect the power cable to mains & try restarting your computer if it starts as normal then it was one of the components had creeped up with the cycling up & down of the pc this is a normal thing due to expansion & contraction of the metals etc that make the components up inside your pc. If this hasn't helped then turn it off at the wall again & disconnect power cable from the wall & computer then you can take out all add-on cards & add the power back to the system & start up your pc if it doesn't start then it is the hdd has either failed or become corrupted & will either need to be recovered professionally or repaired or replaced it is cheaper to replace a hdd than to have it repaired. Yet if you computer starts then shut down add 1 add-on card back to the system & start up if it starts with that add-on card continue to add the add-on cards back in until it fails that's if it a case of an add-on card failing. If it is an add-on card that has failed simply purchase a new add-on card & install remember to remove the old add-on card prior to adding a new 1 unless it is the exact same add-on card to avoid conflicts.
Oct 14, 2014 | Gateway Computers & Internet
I have a asus p4p800-vm motherboard I have everthing hooked up right the front panel wires power from the processor and power supply led lights hdd reset everthing but when I plug the computer up nothing...
Hi, maybe you should download a manual.
From here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800VM/#download
Just to check you have connected everything right.
First select your operating system.
Select manual and click on global for download.
The file has to be unziped before you can read it.
Have you installed the ram module and cpu correct ??
If you have installed a wrong type of ram it will not boot at all.
Does it makes any beep sound ??
Is the powersupply ok ??
If you are useing the onboard graphic check for loose connections.
Check with the manual that all connections are in order.
Aug 28, 2011 | ASUS P4P800-VM Motherboard
My 160gb hdd failed so i cudnt start my pc,for pretty big amount of $ specialist was able to save&backup my data from the failed hdd to a new 160 gb hdd.then i bought 320 gb hd which i filled up pretty...
no it didtn kill the fan NEVER UNPLUG A HARD DRIVE WHILE THE COMPUTER IS ON. YOU CAN. AS IT SOUNDS PERM DAMAGE THE DRIVE.look at the fan. follow the power cord make sure its plugged in right it may have just gotten loose if its in right you may just need to replace it there like 5 bucks. hope this solves your issue let me know
Mar 19, 2011 | ASUS Computers & Internet
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
My 250GB external HDD does not work with the laptop. It seems that the laptop cannot provide enough power for the USB HDD. What can be done?
try a different usb port if fails then update the system bios. download the latest bios from the support site. if still fails in bios then try connecting your ext hdd to a different computer check if its having same problem.
Nov 02, 2009 | Dell Latitude X300 Notebook
Installing new hard drive and monitor says
Turn the computer off.
Disconnect all the disk-drives, both "data" and "power" cables.
Disconnect the CD/DVD drives, both "data" and "power" cables.
Disconnect the 3.5" diskette drive, both "data" and "power" cables.
Turn the computer on.
Better? Worse?
Nov 01, 2009 | MSI K8N NEO2-F NFORCE3 250 ULTRA S-939 ATX...
I have a compac computer with uwave motherboard it says it cant find hard drive whenteyin to turn on
First open cpu cabinet.
Then disconnect power cable and sata or ide cable from harddiks then connect agagin.
Also check your ide or sata cable which connect to hdd works fine.
Refix your RAM memory to.
Then when you power up the computer press F! or F2 or "del" key to enter in bios.
Then check in bios that your hdd is detected?
Then if detected set first boot device in boot optionj in hdd then check.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Compaq Presario 5000 PC Desktop
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
Operating system is .............
power on the computer, immediatly tap f8 until you get to the boot menu. Choose "last known good configuration". If this fails, your master boot record is corrupt.Boot into safemode, copy all of your data to an external hard drive, then reload your operating system from the secondary partition on your hard drive or insert your OS restore disk and follow the directions.
Mar 20, 2009 | HP Pavilion dv6000z Notebook
Compaq Presario SR1030NX (DW256A#ABA) PC Desktop Logo
209 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
