Question about Braun KMM 30 Electric Burr Grinder
Need a manual for Braun KMM10 Electric Burr Grinder
5 Suggested Answers
  • 833 Answers
SOURCE: Looking for users manual
You'll find it here: http://www.lapavoni.com/
Posted on Dec 03, 2007
co7196
  • 3433 Answers
SOURCE: Braun Aromatic KMM10 stops grinding
Soulds like a thermal overload breaker? I know you should not have to do this . Use an outlet that is not shared with any other item, if one is available and if there is a selector for different grinds see if changing it to a finer grind will help. A couarse gring takes more bean ion each pass and it may be too much load on a single extended grinding. One would think the bigger the bin the better the motor. But try this and if you will, let me know. please
Posted on Jul 14, 2009
  • 547 Answers
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Posted on Jan 30, 2010
SOURCE: GVX2-12 Electric Burr Grinder: blue power light not coming on...
Check all connections and plug then after that it is a short behind the switch and will need to be sent back to the manufacturer.
Posted on May 20, 2010
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
Unit is about 6 years old . it takes loger now to grind. is there a part to replace? where to obtain and how to do it. Thanks
You can first try cleaning the burrs, but they are most likely worn and will need to be replaced.
Here is the number for Braun 1-800-816-0810
Mar 01, 2011 | Braun KMM 30 Electric Burr Grinder
Knob interior broke, spring fell out. How do I fix it?
Use quick steel putty to make a new connection for the switch. Tou can shape it and let it harden. Once it is hard sand to proper shape and fit.
Feb 17, 2011 | Braun KMM 30 Electric Burr Grinder
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Jul 10, 2009 | Braun Coffee Makers & Espresso Machines
Food processor
Hi there
the following should be the link to your manual
http://www.service.braun.com/line/HH/H3045/H3045_1_MN.pdf
Best wishe
Sep 12, 2008 | Braun KMM 30 Electric Burr Grinder
Braun KMM 30 Electric Burr Grinder Logo
177 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
