Question about GTCO CalComp Drawing Board III 34180 Graphic Tablet
Autocad 2008 et Drawing Board III (is there compatibility?)
I can't configurate my Calcomp Drawing Board III (Mod. 34180) with the new version of Autocad 2008!!
I can insert the differents points of areas but after i can't choose orders with the table's mouse.
Please, How can i make it??
Thanks, Mercedes
  • Anonymous Feb 17, 2009
    Same issue here. It keeps seeing the tablet as just a mouse.
  • 49 Answers
If you are using the drivers supplied by GTCO, they won't work with Autocad 2008.
They are not a fully compliant Wintab driver. Check with the Autocad software to be sure of what kind of tablet driver it needs.
There is a site called www.vtablet.com that sells a tablet driver that is fully Wintab compliant.
Posted on Jun 10, 2009
NEED WIN 7 DRIVER FOR GTCO CalComp Drawing Board III
Drivers for GTCO, GTCOCalcomp or Calcomp digitizers for Windows XP, 7 and 8 can be downloaded from this url:http://www.interworldna.com/GTCO/gtco-drivers.php
If you are trying to use your digitizer with AutoCad these drivers will not work and you will need to buy a driver from VTABLET.com (They provide a 30 day free trial/demo) only works with serial RS232 interface. If your digitizer uses USB then you will need an interface kit for your specific digitizer to convert it to RS232. Most new digitizers come with USB, some have serial but require you to buy an interface kit. Contact your Digitizer supplier.
If your digitizer is a GTCO, GTCOCalcomp, Calcomp or Summagraphics brand, try these guys: http://www.interworldna.com
They do not know about any other brands. Wacom contact Wacom, Numonics contact Numonics. If you have Mutoh or Science Accessories or any other brand you are on your own as those manufacturers have all gone out of business as far as I know.
Dec 06, 2013 | GTCO CalComp Drawing Board III 34180...
GTCO CalComp Drawing Board III 34480 Graphic Tablet.lectra tablet utilities is not running
First conform that serial port is selected as NONE on digitizer manager while you running the lectra tablet utilities. If you try this already please check your cable connectivity any one of the line may be missing connection. It may work but you can't able to run lectra tablet utilities.
Jun 19, 2011 | GTCO CalComp Drawing Board III 34480...
How to draw a girl step by step
First have a rough copy then make it as rea one
Jul 31, 2010 | GTCO CalComp Drawing Board III 34180...
How do you uninstall tabletworks on an xp machine when it doesn't appear in the add/remove programs list - help! tabletworks works fine it just doesn't work with autocad lt and we need to get rid of it
Control Panel / System / Hardware / Device Manager / identify the tablet and double click on it / 1 - in General, at Device usage put it to disable and disconnect it / 2 - in Driver Uninstall it.
Mar 01, 2010 | GTCO CalComp Drawing Board III 34480...
GTCO Calcomp Drawing Board III connects but won't function...
I HAVE CALCOMP DRAWING BOARD II BUT MISSING ALL CONACTION FOR IT ( CHARAGE , POINTER , 1/O )
PLEASE WE NEED PAY THIS CONACTION FOR RUN
MY EMAIL SAYEDTEBBIN@YAHOO.COM
Jan 06, 2009 | GTCO CalComp Drawing Board III 34180...
I can't get right proportion in X/Y axis in my Acad with DBIII
run the tablet command in acad and configure/calibrate it. should fix it
Dec 14, 2008 | GTCO CalComp Drawing Board III 34180...
Digitalizzing problem
I have a problem with the same hardware and software. I'm using AutoCAD 2008 and when I trace an object that is 1:1 it come into AutoCAD as a different scale. I have tried different scale factors in AutoCAD and nothing.
Jun 02, 2008 | GTCO CalComp Drawing Board III 34180...
I think that the II and the III is the same.
(sorry for my bad english)
I have the II and I have the user's manual, but my scanner it's death...
Mar 26, 2008 | GTCO CalComp Drawing Board III 34600...
If you need documentation, go to GTCOCalcomp.com and they have FREE documentation for your tablet.
It may be a software switch is turned on and is causing this problem. Also check the driver and turn off any mapping.
When you read the manual it will show you how to turn off/on the software switches on the tablet.
These tablets should boot-up in the GTCO binary mode.
Feb 14, 2008 | GTCO CalComp Drawing Board III 34480...
This tablet,when turned on,should only beep once.
It sounds like their may be a hardware problem or corrupt firmware.
Make sure you are using the correct power supply, these use a 12 volt power supply,center negative.
If this fails contact GTCOCalcomp Tech Support.
Sep 13, 2007 | GTCO CalComp Drawing Board III 34480...
GTCO CalComp Drawing Board III 34180 Graphic Tablet Logo
955 people viewed this question
Top GTCO Computers & Internet Experts
William F. Bryant Jr
Level 1 Expert
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
