Question about Topeak Twister Digital Floor Pump
I have a Topeak Twister digital air pump. Worked great for several years but now seems to have a major leak near the top of the airhose or perhaps near the housing for the digital readout display, enough so I cant use it to inflate anything.
4 Suggested Answers
  • 75 Answers
SOURCE: I cannot figure out how to attach football
Older model pumps screw in. Newer models get inserted and then you either push the lever down or pull it up to lock onto the threaded end of the needle
Posted on Nov 12, 2009
  • 4 Answers
SOURCE: pump will not draw air
I think I know your problem: The valve at the bottom of the pump which controls the in-out flow of air can get clogged largely with residue from the gasget as it wears. My suggestion is to take the pump back to the shop where you purchased it as Topeak usually honors its lifetime warantee.
Posted on Jan 19, 2011
Coachphil
  • 347 Answers
SOURCE: Topeak Pocket Shock pump~ can't
When you place the pump head on the valve make sure you flip the lever, this will seal the pump and air will not come back out. Also make sure your valve is not bent or loose. If your still losing air take the pump and bike into any bike shop and they will be more than happy to show you how to use it, and bonus if there is something wrong with either the tube or pump they will be able to diagnose and provide a solution.
Posted on Apr 07, 2011
2000 XJ8 no compression in #4 Cylinder but holds pressure, Help?
My best guess is that the piston is near the top of the cylinder but the leak is below the rings right now where it is. Perhaps a crack in the block near the bottom of the cylinder allowing the leak only during part of the piston cycle.
Mar 12, 2014 | Jaguar XJ8 Cars & Trucks
Does not seem to be pumping air
Most likely the O-ring has worn out, but first take it apart by unscrewing the top of the cylinder where the sliding rod goes thru. Then look at the working end of the rod (opposite end from the pump handle), and put some light grease on the O-ring (it is a black rubber ring), reassemble and test it. If it still doesn't push air out, take the O-ring to a hardware store for a replacement. This usually solves the problem.
Oct 06, 2012 | Topeak Joe Blow Ace Floor Pump
Topeak Pocket Shock pump~ can't find instructions... attempted to use but seems like I loose air..... help
Apr 07, 2011 | Topeak Cycling
Pump will not draw air back in after a pump.topeak master blaster mini dx
Jan 18, 2011 | Topeak Road Morph Pump with Gauge
How do I switch the Topeak mini master blaster pump for presta valve operation? It looks like there's a plastic washer that needs to be reversed but it's impossible to remove.
i've just bought one, they seem pants, un screw the cap, theres a remove the rubber part, tap out the green bit, then just switch it round.
but i've tried pumping my tyre but nothing seems to happen
Sep 03, 2010 | Topeak Mini Master Blaster
I have a Sunlite Air-surge deluxe floor pump which I paid $30.00 about a year ago. I hate this thing. It is NOT user friendly. I have arthritis in my hands. In addition it never seems to secure a tight...
I'm sure if you return it to the store, they will assist you with obtaining a tire pump that is to your satisfaction. I use at Topeak floor pump and have no problems whatsoever.
Aug 19, 2010 | Sunlite Cycling
Leaking from behind?
If the leak is coming from the back of the washer, the problem may be attributed to either a leaking water inlet valve, or the associated internal hoses that run from the valve to the dispenser. The following link explains how to access the inside of the washer and/or replace the valve (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If the leak is coming from under the front of the washer, the problem may be the drain pump. These pumps can develop cracks and start leaking. they are non-serviceable and will require replacing is defective. The following link explains how: http://www.fixya.com/support/r397092-replacing_water_pump Inspect all internal hoses and hose connections as well. There are two drain hoses on the water pump, and several small hoses near the water inlet valve. These hoses can develop leaks over time. If the leak appears to be coming from the bottom of the wash tub, you may have a leaking tub seal, or cracked wash tub (worst case scenario). You will see tell-tale signs of water marks on the gearcase (transmission) if this were the case. On the lower right hand side of the wash tub is an air dome with a small rubber air hoses attached. Make sure this hose is still attached and has no leaks. The air hose can slip off the nipple it is attached to and water will begin to pour out of the washer when it starts to fill. This will be an "attention-getting" leak as water will gush everywhere. Double check the air hose just in case. If parts are required, you can purchase from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deals.
If you have any questions about this repair, or require additional assistance, please let me know. I hope you find this helpful.
Jul 30, 2009 | Kenmore 24032\24036 Top Load Washer
LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Topeak Twister Digital Floor Pump Logo
78 people viewed this question
Top Topeak Sport & Outdoor - Others Experts
Are you a Topeak Sport and Outdoor - Other Expert? Answer questions, earn points and help others
