Need the wiring diagram for Thermalzone air handler mod# TZHSL1817JA
the dr
  • 447 Answers
SOURCE: FINDING A DIAGRAM FOR A RUUD AIR HANDLER ON LINE
I dont have axcess to a wiring diagram but i am pretty familiar i know the heater wiring is crazy on these what are you having trouble with??
Posted on Nov 24, 2007
SOURCE: Wiring Diagram for Ruud Heat Pump
you should give more data as;
Brand of the air handler, the condensor and the thermostat
Posted on Jan 16, 2008
  • 20 Answers
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Posted on Jul 23, 2008
  • 232 Answers
SOURCE: wiring diagram for model # GB5BM-T49K-C nordyne
http://www.nordyne.com/literature/246d.pdf
and if you wouldnt mind giving me positive feedback. Thanks
Posted on Sep 17, 2009
  • 207 Answers
SOURCE: need wiring diagram for york n4ahd20a06a
any york distributor should be able to accomidate u get ur model and serial number and call ur york dealer they should be able to order it and they r usually prett cheap
Posted on Feb 26, 2010
Testimonial: "thank you for your quick response. "
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
I need to know what wiring diagram to use for SSZ140421 Cond with AEPF426016 handler with HKR15C strips.
The AEPF number is for an Amana air handler. I have a manual for this number. Send me an email address and I can forward it to you. Manual has diagram.
Oct 06, 2010 | Goodman CLQ36AR49 Air Conditioner
How to adjust blowed speed on a rheem air handler
There are probably six wires coming out of your air handler blower motor. There are 2 brown wires which are capacitor wires, one white wire which is neutral, and probably red,black, and blue. Look behind the door of the air handler to see the wiring diagram. They should have the color coded speeds marked on the diagram. There is probably some sort of control board that the blower speed taps plug into. By changing these wires around on these taps you can adjust the speed of the blower motor.
Jun 05, 2010 | Heating & Cooling
Putting a mod#rth7500d1007 50033225-001 rev-a the wire inside house is only one wire outside has two four wire hook up do we need to chain to one wire only how maney wire do we need to hook up unit right
HI; A heat pump requires an 8 conductor wire for control low voltage wiring...Thats from the condensor to the air handler and from the t stat to the air handler...
Jan 18, 2010 | Carrier 38CKC042 Air Conditioner
Themostat problem no power
Your R terminal in your air-handler is the 24v power that goes to the tstat. Look at the air-handler and match the color wire. ALL tstats have a power wire going to them. If you aren't getting power, you probably have a break somewhere in the wiring close to the thermostat you are replacing.
Apr 07, 2009 | Ruud UBHC Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Wiring Diagram
Sep 02, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
