Question about Canon PIXMA MX310 All-In-One Printer
The paper won't feed right. Goes in on the right side but the other side won't feed.
  • 50 Answers
Open the covers and check for a paper piece jammed in the path. also look at the little rubber paper drive rollers to see that they havent come off. should like like an oring or little rubber band like strips.
Posted on Oct 10, 2010
Paper jam in cannon lbp3300 printer
Unplug printer and check paper entry feed ,especially the right side,will probably be dirt or a piece of paper stuck in feed roller, use an air duster (aerosol) to blow out dust etc.
Jan 14, 2018 | Office Equipment & Supplies
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
My paper jammed, I (of course being inpatient) pulled it out and now the paper wont feed. Please help.
To fix the error 5200 or E2 or paper won't feed
1. Open the cover printer
2. The right side of the printer, there is a round plastic. Rotate the plastic or gears, as opposed to clockwise
3. Rotate the gears, until you hear the a voice from the right side of the printer (voice shifting gears on the right side of printer). Aiming to restore the position of the skid gear.
I hope this information helps. Thanks.
Oct 18, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon ip2600 won't feed paper
I fixed mine!! I cut a letter size paper in half lengthwise (so it was skinny and long). Held the printer on my lap with both top and bottom trays open. I noticed the white pegs and skinny black roller inside were turning when I turned it on, so I waited til they were spinning and slid the paper between them along the right side. (Kind of a reverse feed). Had to do it between the crazy ink returns. Yes, the paper crumpled a little, and I did it a couple of times with a couple of papers. Something gave, because after that it started feeding properly again!
Oct 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Paper will not feed, goes in crooked. gets caught on right side
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.
Try cleaning the rollers with methylated spirits
Jul 07, 2011 | Dell 725 InkJet Printer
The printer won't feed the paper in properly. It turns crooked and then doesn't load in. Printer thinks there is either no paper or a jam. Can see anything physically in the way blocking the...
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
May 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
My printer kicks out the paper saying i have a paper jam. i do not have a jam as the paper goes right through after i hit ok. i can not see any dirt or lint in the back or front.
Turn the printer off.
. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Nov 06, 2008 | HP Office Equipment & Supplies
LEXMARK 2470 PAPER FEEDER PROBLEM
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck....
Sep 13, 2008 | Office Equipment & Supplies
PAPER FEED
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Jan 16, 2008 | Canon P1-DHV Calculator
Canon PIXMA MX310 All-In-One Printer Logo
53 people viewed this question
old marine
old marine
