My Whirlpool Estate Top Load washing machine is less than a year old. The last few months it has begun to smell really bad between washings. I leave the lid up but that doesn't help. The clothes don't smell bad but the washer does, especially the agitator. What is causing this and how do I remedy it? Thanks!
  • 3 Answers
Chances are there is mold forming in the outer tub, put two cups of bleach in the tub, set the water level at highest setting and run it in heavy wash mode. Do not add any laundry, that should help kill the mold that is causing the smell.
Posted on Oct 09, 2010
Smell coming from AWN32 speed queen top loading washer
All washing machine "smell" when the lid is left closed for more than one day. If it is really bad it might be something inside the body of the machine or something caught under the agitator.
Inside the body work. Unscrew the three screws at the bottom of the front panel. Lift the bottom of the panel forward and up. Remove. Make sure the machine is unplugged and switched off before reaching into the body work. Look for something "smelly"
Agitator - switch off and unplug - depending on the model unscrew the top cap on the agitator. Some models do not have an screw cap although it might look so. Reach with both hands into the machine and grab the agitator at it bottom flanges hands opposite each other. Pull up hard - it does not let go easily- make sure it doesn't have a top screw cap. To replace just push back until it clicks or replace and tighten the top cap.
Dec 13, 2013 | Speed Queen Washer Top Load AWN432
I have the Whirlpool Topload Cabrio washing machine and it will be a year old on Jan. 15, 2011. It is really starting to stink up my laundry room. I have run the wash cycle through with distilled vinegar...
Here is what I do. I run "Tide Washing Machine Cleaner" thru the washer first with HOT water. Then, I recommend running a rinse only with hot water & bleach to rinse the washer out really well and don't forget to leave the lid opened when the washer is not in use.
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Musty smelling washing machine
www.smellywasher.com you can order here to take care of that problem!
Jan 17, 2010 | Whirlpool LSR5132PQ Top Load Washer
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool front load washer smells
I have a front load washing machine too and my instruction booklet says to run it on the clean cycle once a month with the bleach up to the max. I do this every month with out fail. I also the last load of laundry I leave the door ajar. It will usually dry completly in a few hours. Hope this helps
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Washer smells after load
First thing to try is to get affresh washer tablets. They are a new product from whirlpool designed for front loaders to keep the smell out. They also work great for top loading machines. They are about ten dollars a pack. Read the instructions and run the washer through its cycle and the smell get better. The longer you use it, the smell should go away.
Nov 17, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
