Question about D-Link AirPlus DI-524 Wireless Router
Connection HI Your search - http://192.168.0.1/ - did not match any documents. That's what i've got when trying to set up the router Thks to help
    Novelist:
  • 143 Answers
I assume that you're entering it on the address bar of your browser and not on the search field. if so, check if your computer is getting a valid ip address (e.g. 192.168.0.100) from the router. -if your computer has a valid address, try to ping the router's ip on the command promt and check if you'll have replies.if so, try to disable any antivirus software and firewall on computer or try another browser if you have one. also check your browser for any proxy settings. if not, check if the computer is properly connected to the router and there should a light on the port where the computer is connected. if there's no light, use another port or another known working cable. you can also try to use another computer to check if it'll also experience the same problem for isolation.
hope this'll help you with your problem.
Posted on May 30, 2008
    Brigadier General:
  • 6,966 Answers
You need not do a search. Open a browser and enter in the address bar "192.168.0.1". Of course "admin" as a username and no password.
If all else fails, you may need to do a reset of the router by pressing the recessed button normally at the rear of the unit for more than 10 seconds.. Doing so will revert the unit back to factory defaults and will remove any user configurations.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
S3653w dns failed
  • 1. Delete the configured wireless connection if you already have one
  • 2. Enable WiFi but do not perform a search at the moment
  • 3. Open the browser, select Settings > Browser profiles and press "Search for WiFi"
  • 4. Select the connection that you want to connect to and type the details that match the settings on the router
    • Auth type = WPA
    • Encryption = TKIP
    • Network key = router pre-shared key
    • Protocol = HTTP
    • Home URL = address of modem (you can change it later if everything is already working)
    • Leave proxy blank
    • Linger = default
    • Adhoc = off
    • There is no need to change the advanced settings
  • 5. Save the settings but do not connect yet
  • 6. Exit the browser, go to WiFi and select the connection that you have just configured
  • 7. Check all the settings are OK
    • If the channel is different to the one set on the router, adjust it on the router to match the one used by the phone
  • 8. Activate the selected connection and try browsing the internet
That should get everything working. This applies only to personal wireless networks.
Nov 15, 2013 | Samsung Lands Phones
Connect HP 1102w to Linksys wrt54g
Hi! I was able to see that you've got a wireless printer. If you need to connect this to your router, this works like connecting a laptop wirelessly. First, you need to know your wireless name (SSID) and your password (WEP/WPA key). In case that you did not configure your SSID and password, it could be found on your router's sticker. If you were able to configure the two, then you just need to enter it when your wireless printer would ask for these info. If you needed help in configuring your router, I have here a page that you can follow just in case. Please visit http://www.columbia.edu/acis/networks/aptnet/linksys/index.html. This would help you on how you can set-up your router. In case this won't work, you may need to remove the printer's driver from your computer and reinstall it.Try to print a document via USB, just to make sure that it's working, then you may proceed in reconnecting it wirelessly.
Aug 06, 2011 | Linksys Wireless-G WRT54G Router
I cannot connect to our office wi-fi connections. It says authentication failed. how can i able to connect. pls help me.
Hi,Please try these steps:-
Wireless router side
  • 1. Set wireless mode to B-G Mixed
  • 2. Standard Channel = 8
  • 3. Encryption - TKIP
Phone side
  • 1. Delete the configured wireless connection/s if you already have one.
  • 2. Enable wi-fi but do not perform search at the moment
  • 3. Now open the browser and select settings then browser profiles press search for wi-fi.
  • 4. Select the connection that you want to connect to then type the details and match the settings on the router.
  • 5. Auth type = WPA, encryption = TKIP, network key = router pre-shared key, protocol = HTTP, Home URL = address of modem (you can change it later if everything is already working), leave proxy blank, linger = default, adhoc = off, no need to do advance settings.
  • 6. Save the settings and do not connect yet.
  • 7. Exit the browser and go to Wi-Fi and select the connection that you have just configured and select details.
  • 8. Check all the settings if ok. if the channel is different with the router, adjust it on the router to match the one used by the phone. IP address = not connected (it will automatically connect once you browse the internet).
  • 9. Now, try to browse the internet but you must set first the connection you've just configured as default connection.
hope rhis will be helpfull to you. Please rates me. goodluck.............
Feb 03, 2011 | Samsung Star GT-S5233 Cell Phone
How to connect wifi..
  • 1. Set wireless mode to B-G-N Mixed
Phone side
That's it. I hope that this helps. This applies only to personal wireless network.
Happy browsing!!!!
TOM
Jan 03, 2011 | Samsung Star GT-S5233 Cell Phone
How to connect Wi-Fi on SAMSUNG 5560
Please try these instructions:
Phone side
Oct 31, 2010 | Computers & Internet
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
Cant connect my wii get error 51030
This might be handy: http://www.nhotspot.net/wii-error-code-51030/ and http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Verify that the proper Connection File (1, 2, or 3) is selected in the Wii System Settings.
If you have multiple connection files setup, and you have recently received a system update, it is possible that the update has caused the Wii console to select a different Connection File. Click here for step-by-step instructions on viewing your connection settings.
Make sure that your network's name (SSID) matches exactly to what you have entered in the Wii console's settings.
Log in to your router using the default IP (consult the router's owner's manual for assistance).
Look for the section for SSID (typically in the "wireless settings" area).
After you find the SSID (network name), verify in the Internet Settings of your Wii console that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
Oct 19, 2009 | Nintendo Wii Console
Xbox live is not working it keeps coming up with 'you need an active connection to play online or system link matches' but my connection is fi and none of my friends can play as well?
Suggestion: <b>MTU Error</b>
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
Sep 30, 2008 | Video Game Consoles & Games
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
