Question about Teac A-H300 Amplifier
I have a onkyo M-5150 Amp-Was working fine and just quit. I blew a fuse replaced it and now no sound. AMP comes on but no sound. Is there a way to reset this amp
  • Scott Frye
    Scott Frye Oct 09, 2010
    Hi...
    Were you playing it at high volumes?
    and ,the fuse you replaced , was it the external one?
    Sergeant:
    Champion:
  • 387 Answers
Hi
if a fuse blow there is a big chance that another fuse on the main circuit is blown also it should be on the protection unit.
need to take to service
Posted on Oct 21, 2010
Distorted sound / fuse blows off when changing amp class.
The class A switch adjusts, via an optocoupler, the bias on the output transistors.
I would check the standard bias and class A bias adjustments.
Mar 22, 2014 | Marantz PM7200 2-Channel Amplifier
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
M282 onkyo amplifier died during a movie. During one of the heavy bass scenes (a thunder storm), the amplifier just died. I verified all of the connections, and they are good. Tried pressing the on off...
If your speakers are not in good condition you may have floated the cones inducing DC feedback into the amplifier, Im not sure if this amp has internal protection fuses, but I would check them and if so replace with same specification fuses. Sometimes we get lucky... Good luck
Apr 22, 2011 | Onkyo M-282 2-Channel Amplifier
Amp not working
It sounds like you either blew a fuse, or you cooked your amp. The fuse on the P200.2 amp is a 30A fuse, and it sits right next to the power, ground, and remote wire connections on the end. Pull the fuse out and see if it's blown. You should also check any other fuses that you have in the car before the amp.
Mar 03, 2010 | Rockford Fosgate Punch P2002 Car Audio...
Are 2 - 125V 5 amp fuse good enough to use just to check and see if this works...was working just fine. no wires touched..am i looking at a large problem?
Fuse rating would be written on circuit board fuse located, yet 5 amp fuse will work to test the receiver/ amplifier.
If fuse blew off again, then amplifier has problem either in power supply or amplifier output section.
Qualified Tech will fix it.
Thanks.
Dec 01, 2009 | Onkyo TX-DS595 Receiver
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Amplifier problems!!!
it sounds like your running your ohms to low, check to see what the amp can power and then read up online about ohms and your subs and how they should be wired
Oct 12, 2007 | Car Audio & Video
Car Amp keeps blowing fuses
The reason why fuses blow is that the current is too much. Is the fuse rating according to the specs ? If yes then ... One or more output power transistor (or audio power IC) may be shorted. have it checked before replacing another fuse as this might cause more damage.
May 22, 2007 | Profile CL1200 Car Audio Amplifier
Teac A-H300 Amplifier Logo
321 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
