I Have A JVC Av-30w777 n the hdmi port doesnt work i need to kno what buttons on the tv remote i need to use to reset the Tv the remote is a RM-C203G
SOURCE: Insignia TV code for Sony remote RM-V302
press tv, hold setup til tv blnks twice and release setup, type 10463 then power. 5 digit code not 4 like most.
Posted on Jun 19, 2008
dsacco86
  • 1077 Answers
SOURCE: No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
Posted on Jan 29, 2009
  • 105 Answers
SOURCE: REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
Posted on May 27, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
crapiemael
  • 241 Answers
SOURCE: HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
Posted on Jul 21, 2009
Black bar on the screen
This is not the fault with remote control. Check your TV. Contact any experienced service technician.
Jan 20, 2013 | JVC RM-C203G Remote Control RM-C203G-1C
Manual for a JVC AV-48PRO Tv and JVC RM-C265 remote
i have a problem with my TV JVC AV-48PRO its not switching on red and green light blinks and not responding to my remote
Jan 17, 2013 | Televison & Video
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
Accessing the HDMI...............on the TV.....not having much luck.
does ur TV has HDMI port.....and are u receiving HD quality channels
Jun 23, 2011 | JVC RM-C14G-1H Remote Control
Jvc tv remote codes for jvc RM-C745
This remote RM-C745 belogs to a AV-27850, AV-32850, or AV-36850
Mar 10, 2011 | JVC RM-C745 Remote Control
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
Ps3 not conecting on 2 samsung tvs
Your ps3 could be in component mode. You will have to hook it back up on component mode, and go to the ps3 menu and change the setting to hdmi.
Aug 11, 2009 | JVC LT-37X776 37 in. LCD HDTV
I have a ps3 i play my ps3 on my normal television then i put it on an lcd flat screen tv i conected a hdmi cable to my ps3 because i conected put it on an lcd tv. then i put it back on my normal tv but...
ok to reset the video and audio port back to the av port for a normal tv when the ps3 is off hould down the on button unit it beeps 2x fast then it will got back to original setting
if u put in hdmi it will take over the av port so u have to chanage it back to it via ps3 settings or the reset option
hope that helped
Jun 14, 2009 | Sony PlayStation® 3 (80GB) Console
Dog steps on remote and a black screen pops up in the middle of screen but you can see the picture on te outside of the black box. Jvc 32' d-series tv the remote is a jvc rm-c252
Sounds like a closed caption box or a pip box, if not try all the buttons on the remote one by one and lastly try to reset to factory settings if the option is present in menu settings.
Dec 21, 2008 | JVC AV-32S33 32" TV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
