Question about Maytag Ice2O 19.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White
Keypad not responding on maytag ice2o - Maytag Ice2O 19.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White
  • tamikamyoshi Oct 09, 2010
    Already done that still no response
  • Maytag Master
  • 19,396 Answers
Hi.
If reset did not work, then you need to replace either keyboard or Low voltage control board. In some case Hi voltage control board may also be responsible.The test on the keyboard is particularly difficult, as it is done reading volts at the connectors.
I don't know your model number. below an example with model mfi2569vem, an Ice20 unit:
LV Control board is part 3, Keyboard is part 2. Click on diagram to enlarge:
Here diagram2, HV control is part 16:
Testing for this problem is quite complicate. As first step check warranty status by calling Maytag. The most common failure is either keyboard or LV board. No power to LV board coming from HV board can cause less problem. The fridge must be tested.
To contact a technician ring Maytag number on manual. First ensure that you have disconnected power cord or tripped circuit breaker leaving power off for at least ten minutes.
To get parts enter the full model number here.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 09, 2010
    President:
  • 1,796 Answers
Hi!!
First let's try to reset the PCB by unplugging the unit from the wall for a couple of minutes.
Keep me posted, please.
Maytag MFI2266AEQ Refrigerator is leaking water from the bottom right side. Why?
Do you have an ice maker, if so turn off the water supply to the fridge and see if the leak stops.
Nov 11, 2016 | Maytag Refrigerators
I have a Maytag Ice2o that is not staying cold in either the frig. section or the freezer.
hi.because it works for a couple of days.it sounds like u have a problem with 1-defrost timer 2-heater 3-t/stat.good luck.ALI
Jun 29, 2012 | Maytag ICE2O (27 cu ft) Bottom Freezer...
My maytag ice2o starting flashing on the digital panel can I reset it
Your high voltage control board went out, very commonproblem. Call maytag and tell them you know this a common problem amd you also know they are replacing the board out of warranty. Worked for me, to which I also asked they overnight the delivery. Simple ten minute fix.
Aug 24, 2010 | Refrigerators
Keypad does not respond on Maytag microwave MMV5100AAQ.
What usually causes keypad failure is cleaning... spraying it directly with a cleaning solution instead of using a moist cloth on it.
Otherwise, it could be a bad door sensing switch or control PCB. If you haven't already tried this, unplug the unit from the wall outlet for atleast 1 hour and see if it might reset...
Sep 11, 2009 | Maytag MMV5100A Microwave Oven
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Rust on the door edge of my SS maytag Ice2O refrigerator?
Your problem is no doubt a bad door gasket which is not sealing. Water vapor from room air is seeping through and condensing on the door edges. A new gasket should be available from your local refigeration supplier, but they are very difficult to replace. Read all instructions carefully before starting, and store your perishables.
Ray
Nov 16, 2008 | Continental Manufacturing Company Value...
Keypad locked out
Consult your owners manuel for turning off the sabbath mode feature.
try to remember the whole f1 code. if it was f1-1 it could be a temperature problem
if it is f1-4 is could be a shorted keypad
the control pad could be locked out as well. try holding the cancel key for 3-5 sec to see if it unlocks the control
Feb 03, 2008 | Maytag MGR5751AD Gas Kitchen Range
Open Questions:
Maytag Ice2O 19.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White Logo
333 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
