Question about Refrigerators
The freezer only gets down to about 25 degrees, the refrigerator gets to about 45 degrees. I replaced the defrost therostat and cleaned the coils, both fans are running. I'm stumped, Help Thanks, John
  • jtleko Oct 09, 2010
    Sorry, Model #SRD26VW
    Amana Side by side, Model #SRD26VW
  • 4,070 Answers
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 09, 2010
    President:
  • 1,796 Answers
Hi!!
What's your unit's make and model? Thanks
  • Rene J Solis Oct 12, 2010
    Hi!
    First, make sure the Temp. Controls are set up correctly. And verify Temp. with a house hold thermometer. Here is how:
    Setting Controls
    Set controls with a household thermometer that includes temperatures between -5° to 50°F (-21 ° to 10°C). Put thermometer snugly between frozen packages in Deepfreeze ®section. Wait 5-8 hours. If Deepfreeze ® temperature is not 0° to 2°F (-17 ° to -16°C), adjust control, 1 number at a time. Check again after 5-8 hours. Put thermometer in a glass of water in middle of Fresh Food section. Wait 5-8 hours. If Fresh Food temperature is not 38° to 40°F (3° to 4°C), adjust control, 1 number at a time. Check again after 5-8 hours.
    If Temp. Controls are set right, check evaporator coil for ice build up, recheck defrost thermostat installation. Even if you just replaced the defrost thermostat, if refrigerant level is low (due to a refrigerant leak), as soon as the compressor kicks in, the evaporator coil will build ice only on one side (Hi Pressure), the rest of the evaporator will not be as cold.
    Keep me posted!
Freezer not working on Kitchenaid KFIS29BBBL00 Refrigerator Freezer
Is the compressor running non-stop - or is it satisfied at 45 degrees? If it has stopped - the thermostat could be junk. If it is running, the refrigerant coils in the freezer may be choked with frost. This means that the defrost circuit has a problem. One or possibly more of the defrost timer, defrost heater or defrost terminator has failed and will need to be replaced.
You can check by removing the food contents and unplugging it and allowing the freezer to defrost for 24 hours with all doors open. The freezer floor may get filled with water - so be prepared or lay several towels inside to absorb it. Plug it back in and set temperature to 34 - 35. If the temperature settles down to the temperature, the defrost is likely the problem.
Appliance411 FAQ Frost Free Refrigerator Not Cooling Properly
Jul 14, 2015 | KitchenAid Refrigerators
TOP FREEZER- OLDER AT LEAST 12 YEARS OLD- FREEZER @ 25 DEGREES, REFRIGERATOR @ 45 DEGREES- ANYTHING TO DO TO FIX IT?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 06, 2011 | Jenn-Air Refrigerators
Freezer temp reaches 20 degrees refridgerator wont go under 50 degrees on gas or ac dometic rm2807
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 28, 2011 | Dometic RM2620 Refrigerator
Light snow forming in freezer cabinet. Refrigerator cabinet is not getting as cold as it should.
Leo Ponder
imufo2
Jul 28, 2011 | Kenmore 64254 / 64252 / 64259 Top Freezer...
My 7 year old Kenmore (Frigidaire) top-freezer refrigerator M/N 253.73092302 has lost much of its cooling ability during the past 2 months and it is gradually getting worse. Recently, it quit making ice. ...
Not good news by exactly what you said shows a freon leak depending on the location of the leak perhaps on the suction (low side) the likely hood is that the cost of evap coils and or the compressor is better to buy a replacement. Sorry to be the bearer of bad news. What I found here at my location is that L.G. is a poor choice parts take along time to receive and some tech info is hard to get.
May 14, 2011 | Refrigerators
Freezer is not cooling properly. The controls are turned all the way to the coldest setting and the freezer is only about 25 degrees.
it sound like you need to access the evaporator unit in the freezer and see if its iced up and the defrost is working,this can be done by taking cover plate off in freezer section,if its iced up defrost it,clean condenser coils under refrigerator of dust,then turn unit on and see if it cools right again,also if it works for a while then does it again the defrost timer that power the heating coil below the evaporator coil may be bad or the element itself may be bad that defrosts the coil
Jan 16, 2010 | Refrigerators
GE Profile side-by-side fridge and freezer not cooling properly
Could be a few things. Condenser coil clean? Is the back panel cover of the compressor panel in place? It could have a bad part in the defrost system and it's built up with frost on the coil. To see if this is the problem, unplug the refrigerator and leave the doors open for 24 - 36 hrs. then plug it back in. It should work normal again for a few days until the frost builds back up. If this is the case the defrost system needs repair.
Aug 21, 2009 | GE Profile¿ Arctica® Energy...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
GE PROFILE PSW26SGRB SS
If your frig is freezing the food in the chilling compartment as well as the freezer, it means one thing--its thermostat isn't shutting down the compressor when the set temperature has been met. You stated that you had it checked by, I assume, a professional service technician. Being a retired tech myself, I'm surprised that he didn't check this out and discuss it with you. Check the temperature in the freezer! If it is less than 10 degrees F., turn the thermostat to "warmer". If the temp in the freezer is 10 degrees F., leave it alone and go to the temp control in the frig, which is a damper that controls cold air flow from the freezer compartment. Close this damper until your temperature in the upper part of the refrigerator is 38 to 40 degrees F. If these efforts don't shut down the compressor and correct your problem, then the answer is simple. Your thermostat is bad and needs to be replaced. It isn't expensive, and should cost you less than the labor for a tech to install it. Good luck!
Oct 12, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
