Question about Maytag EPICz 3.7 cu. ft. Washer
Maytag/epic z, model mhwz400tq01, keep getting error code f-01, tried to clear following the manual and even unpligged for a few minutes but still receiving this code. Can I further definition of what an f-01 is ?
SOURCE: Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Posted on Jun 19, 2008
Lumpy816
  • 246 Answers
SOURCE: maytag Front load epic z - code f-01
Once you change the CCU, that is where the fault codes are stored. They will go away. To change the CCU, remove the screws on the top of the washer (usually #20 torx or 1/4 screws) Push the lid slightly back and lift off. Depending on the model of Epic z you have the CCU will be on the top, center towards the rear or on the top, right hand side towards the front. It will be the plastic box where all of the wires are going. However, before changng the CCU, unplug the unit for 2 1/2 minutes. Does the problem return? While you have the top open, check all of your connections going to your CCU. Are any loose? Also try following the black hose on the top, right hand side towards the rear. It goes to your pressure switch (round cylinder 2 1/2 - 3" wide). Give it a firm tap with something insulated (the handle of your screw driver for instance). If the switch gets stuck it can cause a false f01 eror code.
Lumpy816
  • 246 Answers
SOURCE: maytag f-o1 code , says
Unplug the unit for 2 1/2 minutes. Does the problem return? Open the top, check all of your connections going to your CCU. Are any loose? Also try following the black hose on the top, right hand side towards the rear. It goes to your pressure switch (round cylinder 2 1/2 - 3" wide). Give it a firm tap with something insulated (the handle of your screw driver for instance). If the switch gets stuck it can cause a false f01 eror code.
  • 3 Answers
SOURCE: maytag epic z washer flashes
I had the same problem and the code f01 would flash, I could select the wash and make selections with all the other buttons but once I pushed start it would flash f01. I fixed the problem by not turning the machine off and pulling the power cord out of the wall and it seemed to reset it. I could immediately turn the machine on and it stared working.
Posted on Jul 23, 2008
  • 409 Answers
SOURCE: I just purchased a floor
hi there,
you may have a shorted thermistor.
can you tell me when this problem happens?
also, can you provide me with a complete model #?
thanks
Posted on Sep 27, 2008
MAYTAG EPICZ DRYER ERROR CODE F-01
F01 means the main control board or "micro computer" has detected an internal short. Unfortunately, the only way to correct this issue is to replace the control board itself. It's under the top panel in the front right corner.
Dec 05, 2013 | Dryers
Maytag epic II washer error codes, especially error code F 21
HI. Click here to download the complete service manual for this unit. All the repair procedures and error code definitions can be found in this repair manual. I would advise to save this PDF to your HD for safe keeping.
May 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Aug 26, 2008 | Maytag MAH6500 Neptune Front Loading...
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Maytag Front load epic z - code f-01
Jun 19, 2008 | Washing Machines
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Jun 16, 2008 | Washing Machines
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
FDL error code
"Fdl" is an error code for Whirlpool Duet and Kenmore Elite HE front loader washers. I'm not sure if this error codes also applies to the new Maytag models. I believe Whirlpool has taken over the manufacturing of some Maytag appliances, but I'm not sure. If you've only used the washer a few times, and have not slammed the door, overloaded the washer and have been following the your owner/operators manual recommendations, then you need to get in touch with the retailer and/or manufacturer and request a service call. Your washer is still covered under a limited manufacturer's warranty that covers failed components for the first year. In many cases, attempted repairs or disassembly by the consumer can void the warranty. To answer your question: Sometimes components fail for unexplained reasons. It could have been a bad part that came from assembly defects and/or shipping damage. The only way you could have created this problem is by slamming the door or overloading it to the point where it stresses the door when closing it. I hope this answers some of your concerns.
Jun 12, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPICz 3.7 cu. ft. Washer Logo
160 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
