Question about Mantis Tiller
Have a 1981 mantis with no priming bulb. was running yesterday then stopped.new gas 50 to 1. new gas filter and gas line. gone to matis hot line for starting.how do i tell if card. need cleaning and is it easy to disasemble and clean.bought it thru ebay. had it 2 days.started and used a total of 1 hour.now it dosnt start..disconnected switch wire still unable to start.
    President:
  • 2,777 Answers
It sounds like it mas some major problems for sure... did you buy it locally on ebay or had it shipped to you? My recommendation is that you return it, that thing is going to be trouble no doubt about it.
Tim
Posted on Oct 09, 2010
Bulb will not prime
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
2 stroke Mantis Tiller 1) Very difficult starting, when started, high rev works, but 2) Engine dies on deceleration. Carburetor is signed C1U K4589A. The priming pump does not suction, gasoline...
Hi there is a small stone fuel filter in the tank. this filter stops fuel from running back into the tank from the carb check to insure it still on and make sure there are no cracks or hole in fuel line that should fix your problem
Aug 31, 2011 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
did it also run out of oil, because it seized like it did you might of burnt the engine
May 31, 2009 | Mantis Tiller
MANTIS WILL NOT IDLE
What kind of engine is it ? Does it have a float carburetor or diapram carburetor ?
May 09, 2009 | Mantis 2-Cycle Tiller
Matie 2 cycle will not run when throttle is ful on.
Make sure all of your bolts are tight, especially the ones on the carb. If so you will need to clean the carb.
Mar 27, 2009 | Mantis 2-Cycle Tiller
My 2 stroke mantis tiller will not prime.no fuel in prime bulb. I guess no suction. Fuel lines are clear.Which parts need to be replaced?
I had the same problem, get a rebuild kit. It sounds like the diaphram is shot. Also make sure the prime bulb doesn't have any holes or cracks, the engine won't run if it does
Mar 21, 2009 | Mantis 2-Cycle Tiller
Mantis Tiller Logo
18 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
