Question about Sony Cyber-shot DSC-W55 Digital Camera
How to initialize
Can u tel how to Initialize the camera.. i searched in options but i didnt get tat .. can u tel clearly under which menu ??
  • 10,594 Answers
Push Menu switch, go to Set-up and select Set-up1 and downwards there is option Initialize. select it and press Yes. Camera will go to power Off and On itself. Date n time adjust option will come and adjust current date n time and have fun. :D
Posted on May 30, 2008
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
The camera turns on but only loads the 'cyber-shot' screen then freezes, lens doesn't open, can't view past pictures or do anything including turning it off. Camera was not dropped or man-handled in...
I'm sorry to hear that the Camera is not working as expected. I suggest you to follow the steps mentioned below to check if the issue can be resolved.
Perform the below steps to power reset the Camera.
Turn off the Camera.
Allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack.
Turn on the Camera.
To Initialize option in the Camera can be done only if you're able to access the Menu of the Camera. To Initialize the Camera select the INITIALIZE option from the Main Settings Menu option from the Settings Menu of the Camera to OK. (You may try this only if the Menu is accessable).
If the issue persists, service may be required.
Thanks for using FixYa.
We wish you a Happy Holiday Season.
Dec 18, 2010 | Sony DSCW320 Digital Camera
WHERE IS THE RESET BUTTON IN THIS CAMERA
The Camera does not have reset button. You can reset the Camera by either using the Initialize option from the Menu or removing the battery.
You can find the Initialize option under the Setup Menu of the Camera.
To Power reset the Camera, remove the battery it, press and hold the power button for more than 15 seconds and then reinsert the battery.
Thanks for understanding.
Dec 18, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I need to reset the camera!! it turns on and says turn off & try again
to reset your camera, turn it off, pull the battery. With the battery pulled, press and hold the power for 30 seconds. Release the button, then put the battery back in and power back on. This should clear any power messages.
Jun 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Flash bulb not fuctioning my camera sony cyber shot dsc w55
1.Try initializing the Camera.To initialize the Camera, select the "Initialize" option under the "Setup 1" Menu of the Camera.
2.Even if the flash is set to always ON, the flash will still not work in the following circumstances:
* When shooting MPEG movies.
* When shooting in the Twilight or Handheld Twilight mode.
* If shooting with the Burst or Multi Burst mode.
* Shooting with Sweep Panorama.
* Shooting with the Fireworks or High Sensitivity mode.
* If an external flash is connected.
Refer:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C95364
Oct 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
ACCESS???
1. Please make sure that you're using a fully charged battery.
2. Please try Initializing the Camera. To initialize the Camera.
First, press the Menu button on the Camera to display the Menu items.
Then, select the SETUP option under the Menu.
Then, select the SETUP1 under the SETUP.
Then, select the Initialize under the SETUP1 option to Initialize the Camera.
If the issue still persists, then try Power Resetting the Camera.
First, turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the Power switch for 30 seconds.
Then, reinsert the battery pack into the Camera and turn ON the Camera.
If the issue still persists after performing the steps provided above service of the Camera is required.
Jun 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Sony DSC-T700 PURPLE FLICKER
Let's try Initializing the Camera.
If you're able to access the Home Menu select the SETTINGS in the Home menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize option under the MAIN SETTINGS to initialize the Camera.
If the issue still persists try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is required.
Jun 14, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Looking to reset to original factory settings
On the camera's menu system, under Setup2, look for the option titled "Clear Settings". When selected, you can either clear just the Custom Settings, or you can clear all camera settings, which restores it to the factory defaults.
Jan 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
How do i initialize this camera to see if that works?
Initialize option is vailable in camera Menu. Please check menu
Aug 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
It is with the picture it is not clear and some times blue
Initialize your DSC-W80 by selecting menu > initialize option and enjoy.
Jun 03, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
32 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
