Question about JUMP START SYSTEM
I have Power on Board jump starter air compresser&12volt DC power supply VECO21STC. Compresser works ok but needs the gear that turns the compresser it has broken a couple of the teeth off. Can it be replaced and where can I get one? Thanks for any info fitz683
Where can i buy the power cord to recharge my Power on Board 12 volt 450 amp
Posted on Jan 14, 2011
  • James Pendergast Dec 14, 2013
    www.powerpayless.com 19.95, AND IT WORKS FOR 450 AMP POWER ON BOARD
I need a 110/120 volt ac/dc adapter power cord for recharging from standard wall socket. For a Peak 450 jump starter
After searching the internet for a ph number for Peak power I finally found the web.
http://www.peakauto.com/contact/site.
phone 800-323-5400
If the part department doesn't have the answer ask to be switched to tech support.
They were able to provide me with the part numbers I need for new wall supply cord and an DC adapter for the car.
My jump starter is no longer made...
Nov 15, 2013 | Peak Performance Peak PKC0BL 450 Amp Jump...
Lost the power adapter for my Power-on-Board Jump Starter 400 Amp VECO21STC unit. Where can I purchase a replacement adapter?
I just checked eBay they have a bunch if them from $ 8 and up..check it out good luck..
Jul 19, 2011 | JUMP START SYSTEM
1993 ducati 750ss 12.5k on the clock not starting clicking noise from possible starter relay but turning motor over battery is showing 12.35 volts with all lights/horn etc working ok anyone have any ideas?...
Sorry should your thread say clicking but not turning the engine over? A battery may show a 12volt dc voltage on a meter, but not have enough amperage to turn the starter-engine, when you press the starter with the lights on are the lights affected, do they go dim or remain unafected? At the starter solenoide with the ignition turned off bridge both the thick starter leads with a pair of insulated pliers, care must be taken not to make a spark, so pliers on and the engine should turn over, if the engine does not turn over then it is likely the battery has insufficant charge or the starter it self is not working, you should next try a new sorce of power, power pack, or jump leads from another battery before making your asesmant, on purchaseing a new battery, good luck paul
Apr 29, 2011 | 2002 Ducati 750 SS
Need a charger to charge my Jump Starter BP-DLG
Need confirmation that the AC adaptor for Duralast jump start model BP-DLG is a 12volt 450ma. Is this correct or do I need something else?
Nov 06, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Blinking red light won't start
No Power (Totally Death).
  1. Check the output regulator 12volt DC Power Supply.
  2. Check the Fuse (Voltage Security Fuse).
  3. Check the Flexible cable on switch board (reset & eject button).
  4. Check the Output Diode.
  5. Or check the I/0 button.
Sep 17, 2010 | Sony PlayStation 2 (PS2) Console
When you turn on air conditioner it cools after a few seconds compresser shuts off an you get warm air?
Hi,the problem you are experiencing is as a result of a faulty starter relay of the compressor,which supplies power to the compressor,here is the solution yo your problem; Remove the cover from the back of the AC depending on the brand of your ac.
you will find a component attached to the side of the compressor,usually black,this is the starter relay that needs to be replaced,remove it and replace it with a new one.
Afterwards,your unit will be restored back to a normal working condition.
Thanks and take care
Jun 19, 2010 | Heating & Cooling
Air ride suspension is not getting current to the compresser
I would suggest a salvage yard and replace the bag I would also check the compresser and get a 12volt tester and test all the curcuits because if it burned out a fuse you may have an opened curcuit somewhere
Jan 03, 2009 | 1999 Lincoln Town Car
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
JUMP START SYSTEM Logo
1,587 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
