Question about GE Microwave Ovens
Microwave popped when pressed selection and went out and will not come back on. it is 14 hours old.
  • GE Master
  • 9,098 Answers
Did you check your breaker & outlet?
I would unplug it for 1 minute then plug it back in and try again.
If it still fails, I would contact GE Customer Service for warranty service. They're at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
How to I reset the language back to English
Press the Settings or Options button. Each time you press it, you will get a different option (beep tones, 12/24 hour clock, and somewhere in there, language). Look for something that looks like language and select English (or Ingles). Then press Start or Stop or Cancel.
Jun 29, 2014 | Kenmore 62622 Microwave Oven
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Microwave Settings
look for the clock or watch symbol on the keypad. When you press it, it will show you a 12 hour(normal time) or 24 hour(army time indication).Select the correct time by pushing the hour then minute buttons. Once that is done, press the clock symbol again whick accepts the setting.
Jun 06, 2010 | GE JE1660 Microwave Oven
Went to turn on the mic and heard a pop and now no power. think i blew a fuse. changed it and same thing all over again. any ideas???
I had the same thing to happen to our microwave oven. I went and replaced the fuse in it. Power came back on. Then I tried to pop some popcorn in it. 30 seconds after it started, it made a vibrating noise and shut off. It took the fuse but not the curcuit breaker. The microwave is 14 years old. I have just come to the conclusion that there is buildup all inside the motor parts and that it needs to be replaced. The instruction manuel mentions to replace the monitor switch when replacing the fuse. Since I lost the manuel a long time ago, I asked at Lowes and noone knew what that was....I since found out that it was a safety device installed on the microwave oven so that if the door was not shut completely or was out of alignment, it would throw the fuse. Anyway, I am happy with the service we got with this microwave. It has been through several slammed doors and lots of use. We have been very satisfied with our Frigidare Microwave. It has held up well.
Oct 15, 2009 | Frigidaire FMT118E1B Microwave Oven
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
14 month old LG Microwave. The control panel is
Very common , You need to replace the switch membrain , this is the entire touch pad , they are not to much $ , and you should find it easy online.
Phil
Apr 10, 2009 | LG LMV1630 Convection/Microwave Oven
GE Sensor Microwave JES1855 died
Mine went dead after about 6 months. I had problems with my breakers and I found out that it was the microwave that blew all of them. I also found out that this perticular microwave is a fire hazard and should be recalled. It has caused me alot of headache. The breakers in my house are brand new and they are put out by GE also. It caused me to loose the food in my freezer, I did not know my freezer had lost power. It would cause my entire lights to go off and then they would come back on. I have checked around and I found out that the power cord on the back of the unit is very loose. I had a person to come in and look at it, he thinks its the power cord.
Feb 20, 2009 | GE JES1855 Microwave Oven
Shuts off, must reset clock
Sounds like you could have a fauly control circuit. Something like when you press the pad the processor does not interpret the information correctly and resets itself. Or the power going to this circuit is being interupted. It is VERY dangerous to work inside of a microwave. So you could get an estimate from a repair shop. But those control boards are expensive. Do not attempt to repair this yourself. For your own safety.
Aug 06, 2006 | Frigidaire PLMV168 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
