Question about Motorola Mobility RAZR V3
My phone cannot find any of the networks which are certainly available in the area that we are in (France) I try to select networks, but it can't see any of them.
  • 567 Answers
There could be a couple of reasons why this is happening.
If you are not in the home network, please ensure that international roaming is activated. Your service provider can do this for you.
Try to use a SIM card that is a local one and see if the phone picks up a network.
Is this a new Phone or a new connection? I mean, has this phone and SIM ever worked for you before?
You might want to set the phone to "Automatically Select" the network and see if it picks up the default network of your service provider.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Oct 09, 2010
Putting the password from the modem to my new phone so I can have wi fi
Go on your phone settings and search for wifi settings, and try searching for available networks, you should have a list of available networks it can be from one option to many, depending on the area and how many people/neighbors have wifi around you. Next step is to identify which one is your wifi network is and select it and then connect/join, after that you will be promoted to enter the password for the selected network. That's pretty much it, the settings change depending on phone, so adding details to your question can help you get a more accurate answer. Hope it helps.
Feb 21, 2017 | The Computers & Internet
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
May 02, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
Network connection not available...what i suppose to do?
first go to phone settings->operator selection browse and choose ur operator or switch on and off ur phone mostly problem will be solved if not network is not available in your area you should go to a place with good network and use it.
Oct 29, 2011 | Nokia 5730 Xpress Music Mobile Phone -...
I ve a nokia 2730 classic model ...m using airtel service... when i set umts mode there is no network coverage
This probable if your Network does not have 3G/UMTS coverage in that specific area.
I would set your phone so that it will automatically select 2G or 3G network services (e.g. often referred to as Dual-mode) so that if 3G/UMTS is available and has the best coverage/signal, it will automatically be selected. Setting UMTS coverage only would be very restrictive in many area as the signal is usually weaker (especially in Buildings).
Hope it helps!
Sep 24, 2011 | Nokia 2730 Cell Phone
My gt b-7610 cannot connect with wi fi,how can i fix it?i already tried to do on settings but still it wont work out.pls help me.
First make sure the wifi is enabled..and after that get into the feature and select to search for networks ..when you find your network ..select it and hit connect ..If it do not want to connect it means the settings on the router are not compatible with your phone ..This model only support 802.11 b and 802.11 g networks .. So if your router is on d it may be a problem ...In this case select other wireless networks with no protection ...in the area..and try to connect ..or ..make sure the router is compatible ..and remove the protection on the settings ..and try again ...another issue may be the frequencies ...all routers have a scale from 1 to 12 or so ...select a middle one to be sure you are in the range ..
If you do not use a router ..but you are trying to connect to a network found in the area..you need the access password if it is not free..
If the search do not find any network available ..it means there are no wireless networks compatible in the area..
Jul 20, 2011 | Computers & Internet
3315 no signal
Go to menu>settings>phone>operator/network selection>mannual.
After doing this your phone searches for available networks from your area. After that,select your network.
If the problem exists,it is hardware problem.
Thank you.
Apr 29, 2011 | Nokia 3315 Cellular Phone
Whats the restriction code for the lg c2000???????? Help!!!!!!!!!
Hi,you can unlock your mobile by unlock codes..the safe and best way of unlocking is by unlock codes and my personal request is that don't go for software unlocking because sometimes the software might get corrupted and may your data will be lost due to that,its my bad experience so I went for unlocking by codes from here UnlockGenie.com and unlocked.you can too try but see to that whether your country and provider is listed..because for some service only codes are available..check with that and if your country's provider is listed then get codes and unlock your blackberry..before unlocking your mobile you can get clear instructions about how to unlock your mobile for that you can visit UnlockGenie.com to get step by step instructions..
Jan 28, 2011 | LG C2000 Cellular Phone
MY Nokia 6610i keeps telling to select network especially if i put it in my pocket.What is the problem?How do i solve it?
i think your phone's network connection is in manual. You should Press Menu, and select Settings, Phone settings and Network selection. Select
Automatic and the phone automatically selects one of the cellular networks
available in your area.
Apr 16, 2010 | Nokia 6610i Cellular Phone
Bought LG 275 in france but could not work in nigeriaa
The phone could be locked to the networks in france. Try unlocking it, ask a technician to do that.
Jul 08, 2009 | Cell Phones
Network problem in nokia 2310 i have no network on my nokia 2310 .please help me out
good day,
check if your location is covered by your mobile network service provider. you can also verify the available network by going to the "Settings" of your phone and selecting "Network Settings" then select "Manual."
however, if you are certain that there should be a signal from your network provider in your location, have your unit checked by a competent nokia technician, there might be a problem with the internal antenna of your phone.
i hope this will help
Oct 03, 2008 | Nokia 2310 Cellular Phone
Motorola Mobility RAZR V3 Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
