Texas Instruments TI-89 Calculator Logo
Posted on Oct 09, 2010
The calculator don't turn on even that I put new baterries
  • kakima Oct 09, 2010
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the diamond key. Press and hold the + key for a few seconds and see whether the screen becomes legible. Does it?
Anonymous
Level 1:
  • Contributor 37 Answers
  • Posted on Oct 12, 2010
Anonymous
Contributor
Level 1:
Answers
37
Questions
Helped
3878
Points
90
Check the contrast. Someone might have been messing with you and turned it really high, so everything is white. Turn it on, and then push and hold 2nd, then the down button (possibly up... I don't have it with me at the moment, so I can't remember which one.) You should see something now. Tell me how it works out, and hope this helps!
The remote control on the morphibian shark doesn't work even when I put new batteries in it
hi julie if you put a new pair of baterries in right direction
and no work
take it to nearest electronic repair shop
Ti84 keys not working
hi
press the clear key if this don' t work try finding the
the reset button in the back of the calculator or remove the batteries from it for one minute and put them back in and turn it back on again . if that fails than buy a new calculator because you got a defective calculator that some how got pass inspection.
I hope this helps
Nikon Coolpix L21 exhausted baterry
Are you using the correct type of battery? Those cheap disposable carbon batteries simply cannot power cameras. you need at least alkalines. even better- lithiums or Ni-MHs.
My calculator wont turn on. Even though i put new batteries in correctly. How can I turn it on? Nothing happens when I press the ON button.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
2helpful
My calculator wont turn on even after putting in new batteries
If this doesn't do it, please append a comment to this post and we'll go on from there.
2answers
It wont turn on, tried new baterries and everythig, can i send it in to get fixed?
Having received no response in over a month, I assume this is no longer a problem.
I put in new batteries into my calculator and the calculator still does not turn on help?
Try the memory battery. The button battery under the cover with a screw. Also try putting the baterries in and spinning them, this will help remove corrosion. Lastly take apart and look for a broken battery terminal, may need solder.
2helpful
2answers
TI-89 won't turn on, even w/ new batteries
Try a hard reset:
Press and hold the 2ND, Left, and Right keys.
Press and release the ON key.
Be aware that this will clear all RAM.
When I put brand new batteries, it says "Change Batteries"
Use a Q-tip with alcohol to clean all the batter contacts (battery cover and inside the battery compartment), and a small hook into the compartment to pull up the contacts a little bit up. The idea is to make the batteries connect properly.
Use NiMh rechargeable batteries or Alkaline batteries, don’t use other Dry batteries, which are not designed for digital camera.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
