Question about Allied Telesyn AT 8748XL Networking Switch
Hi, I'm trying to connect a switch to another switch and it isnt working. Ive tried using the crossover cable and straight through and neither are working... Any help you can provide would be greatly appreciated.
My Hp office-jet Pro X576 printer is connected via a network and if l send a print job it displays printer error switch off machine and the printer restarts .if l use usd it works fine
I would ensure that you have the current firmware installed on the printer and make sure that you are sending the job via network with a correct driver. If you manually set the IP address on your computer and the printer you should be able to connect direct using a crossover cable, I do that in the shop all the time.
Dec 11, 2014 | HP Officejet Pro X576dw Network-Ready...
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
I have a gs724t and need to add a gs748t, what cable do I use to link them together??
Most switches are smart enough to detect and reverse logic if the wrong cable is used. If you want to be correct you would use a crossover cable.
Computer to computer, router, or extender (crossover)
Computer to switch or hub (straight through)
Switch/Hub to Switch/Hub (crossover)
Dec 30, 2011 | Computers & Internet
Hello Dear, I have 2 D-Link 10/100 Fast Ethernet Switches and 1 Broadband Connection (which requires Username & Password) and want to simple networking in my office lab i.e. pc to pc networking not...
my dear, you a router in order for you to connect or use your simple network . . you don't crossover cable in that particular situation . . here's the connection . .
1. from WAN to router - you already have that i know
2. from router to switch - use straighthrough cable
3. from switch to pc's - again straight cables . .
i hope this will help . .
Jan 14, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
How to use cross cable and straight cables in network
ok, i think what you mean is this.  Crossover cable is for connecting 2 computers together without the need for a router.  also called pc-to-pc.  Straight cables need the use of a router or hub to connect 2 computers together.  Hope this helps, if not let me know more info.
Mar 06, 2009 | Southwestern Bell (S60802)
I cant get onto the internet with my playstation 3 .
If u can get online Playstation Network to the point wer features like adding friends become availible then there shiould be no problem. If you cannot sign in to playstation network then there is a something wrong with your network aettings. If an arror code comes up type into google something like "What does error code *********** on the PS3 mean???". Be specific
Jan 14, 2009 | Sony Playstation 3 (PS3) Console
Crossover Cable
crossover cables are designed to connect two DCEs (data communication equipments like modems) or two DTEs(data terminal equipments like computers)
most routers nowadays have smart ports so you can use either a crossover or a straight-through cable to connect a computer. but if your router doesn't have smart ports, it's advisable to use straight-through cables
hope this'll help you
ciao!
Aug 19, 2008 | 2wire (1000-400108-001) Router
Pc's say a network cable is unplugged
First, NO, crossover cables are for connecting LIKE devices.. you need a Straight Thru cable for connecting 2 PCs to a switch.. So, if you are using Crossovers, then you are getting the correct results (cable unplugged). Replace with the proper cables, and it should see the network fine..
Also,
As this ProCurve HP 408 is 10/100 auto sensing, you should be able to automate speed and duplex within your NICs conifiguration...
Happy Holdiays!
Dec 22, 2007 | HP ProCurve 408 Networking Switch
Allied Telesyn AT 8748XL Networking Switch Logo
20 people viewed this question
Top Allied Telesyn Computers & Internet Experts
Prashant M
Prashant M
Are you an Allied Telesyn Computer and Internet Expert? Answer questions, earn points and help others
