Question about KitchenAid KCM511 Coffee Maker
Err 2-repeatedly unplugged, turned on/off, pressed all buttons. NOTHING>
  • Anonymous Jul 01, 2008
    The same thing has happened to me. ERR 2 message keeps coming up. I have also unplugged, turned on/off. I have also let it sit for awhile, before trying to turn it back on. (no luck)
  • 231 Answers
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR!Put a tiny bit of vinegar in the carafe and fill carafe the rest of theway with water. Run that vinegar/water through machine. Using anothercontainer, fill machine with plain water and run that through. Repeatuntil the vinegar taste is gone. If you do not run lots of plain waterthrough the machine after, your coffee will tastelike...um...disgusting!
To clean hard water deposits from acoffeemaker use distilled white vinegar. You may need to use as much asa gallon if the scale buildup is really bad. Fill clean coffee potone half full of vinegar and run through machine as if makingcoffee. Repeat this process several times using fresh vinegar until itcomes out clear. Do this once a week and your maker will work muchbetter.
Posted on Dec 27, 2008
Clearing a Print System Failure on the HP Photosmart C6150 All in One Printer
Try the below steps to bypass the error.
1) Press * and # at the same time
2) Press 1, 2, 3 and "support R0632M" should display
3) Press > and "information menu" should display
4) Press > and "configuration menu" should display
5) Press OK and "hardware failure status" should display
6) Press OK "failure status: clear". Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
You may need to repeat the above a few times as the error can change.
Aug 04, 2013 | HP PhotoSmart Office Equipment & Supplies
Tried to unlock the region on a samsung d530 now nothing works. Can i restore factory settings? thanks
Here is the steps to make your dvd player region free:
1. get the system grid to change region.
2. change to region 2 first.
3. then change to all regions.
Part 1 -> Getting to the grid
make sure the disc tray is closed
press buttons below one after each other
1) Repeat
2) Fast Reverse (3) Next Ch (>>')
4) Fast Fwd (>>)
5) Prev Ch ('6) Play (>)
Take a note of the highlighted numbers (just in case!) in
case you need to do it all again.
Part 2 -> Change player to region 2.
Using the grid make your player into region 2 by
highlighting the numbers 2,8,19,21,22,24 then PLAY button to
save settings(this will turn your player off - you need to
turn it back on by pressing power button
Select the language again then proceed to part 3.
Part 3 -> Change player to region 0 (all regions)
Press the following buttons:
1) Repeat
2) Fast Fwd
3) Fast Rev
4) Fast Fwd
5) Up
6) Down
You should see a 0 on the top left corner!!!
Player is now REGION FREE.
Jul 30, 2011 | Samsung Televison & Video
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
I have a conon pixma mp198 error 27
ink absorber is full is canon error code E27. Try doing this steps to help you fix this problem.
Unplug the power cord then Press and hold down the Stop / Reset. After that Insert the power cable
and Press and hold down the power button (the button Stop / Reset fixed in press), When pressing the Power button, then release the button Stop / Reset. Press the Stop / Reset 2 times then release the Power button."Wait until the digit 0 appears in the display"
> Push down the Stop / Reset 1 time.
> Push down the Power button 1 time, the printer will print a sheet of paper.
> Press the Stop / Reset 2 times.
> Press the Power button 1 time, the printer will mecetak a sheet of paper
> Press the Stop / Reset 3 times.
> Press the Power button 1 time. (No printing)
> Press the Stop / Reset 4 times
> Press the Power button 1 time rather long and loose (to turn off the printers).
"If the printer still can not get turned off, unplug the printer power."
> Turn on the printer.
> E27 error message is gone & the printer is running normally.
Nov 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
I came home today to find that my desktop was off after being previously on earlier when I left the house this morning. I went to turn it on and nothing happened. I got down next to the machine and tried...
>This may not be a resolution but it's worth giving it a try: ?
>Unplug power cord from both the computer and the power outlet
>Press and hold power button down for approximately 20-30 seconds(this is what we call Power Drain: it gets rid of electrical charges on the motherboard which may cause these kind of problems)
>after 20-30 seconds plug the power cord back into the computer
>Turn it back ON
>I really do hope this works
>comments suggestions ratings and violent reactions will be greatly appreciated
Sep 23, 2010 | Gateway Computers & Internet
I put new cartridges in my photosmart c7280 printer and keep getting a Wrong Cartridges message. No matter what I try (putting in previous working cartridges, cleaning points) nothing changes. HELP !
Try these 2 procedures:
1/
- Unplug the printer without turning it off.
- Press On for 1O seconds.
- Release the button and replug the printer.
2/
(Careful, this will erase the printer's memory, like printing queues etc.)
- Unplug the printer.
- Press simultaneously "#" and "6" and keep these buttons pressed.
- Replug the printer without releasing these buttons.
- The display will say " Stop " or something like this, then "semi full reset" . Release the buttons now.
- Start the printer now. It will ask you to set the language and the country. If it doesn't, repeat all steps.
Jun 22, 2010 | HP Photosmart C5180 All-In-One InkJet...
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
KitchenAid KCM511 Coffee Maker Logo
1,077 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
