Question about Microwave Ovens
Manual for intregrated fridge freezer diplomat apm 6855-1 about 2 years old
I have a ten year old Amana bottom freezer refrigerator bx21v1c,and the compressor has died. I am debating as to whether to buy a new refrigerator or to pay up to $800 to replace the compressor.
There is no way that I would spend $800.00 on a ten year old fridge... I can do my own and I would not replace a compressor on a ten year old unit...too many problems afterward...too many other things that could go wrong shortly...
You will be better off to take the $800.00 and put it towards a new unit...
heatman101
Jun 10, 2011 | Microwave Ovens
Just started to experience an intermitent wining noise which seems to be coming from the freezer section. Fridge freezer is just over 5 years old.
shut it down allowing a defrost for 2 hrs remove any ice build up ,Check also the machine is level on floor and feet adjusted so no wobble...good luck
May 03, 2011 | Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
I have a 2 year old LEC T2856w fridge freezer and the fridge keeps freezing everything, it seems to be warmer at the top and makes a wall of ice on the back
That sounds like an a refrigeration engineer is required as if the gas pressure has dropped, it will no longer cool properly.
Mar 07, 2011 | Microwave Ovens
Maytag Bottom Freezer Fridge only a few years old was replaced to sell the house. We just bought our house, moved in and the dishwasher wasn't working so we got a new one. Now our fridge is humming and the...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 03, 2011 | Microwave Ovens
Diplomat Range Cooker User Manual
There should be a source of manual here;
http://www.google.co.uk/search?q=Diplomat+Range+Cooker+User+Manual
I can't find Diplomat as a manufacturer, sorry
Jan 03, 2011 | Microwave Ovens
I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
Engineer told me not to waste money calling them out again, and to buy another one...
Oct 17, 2010 | Microwave Ovens
My freezer is working fine but the fridge is not cooling. It is a kenmore side by side 26 inch and is 9 years old.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 24, 2010 | Microwave Ovens
The fridge I have is only 4 years old but continually freezing items. eg 2litres of milk overnight!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Microwave Ovens
Microwave Ovens Logo
662 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
